oil slinger needed or not? #3201524
01/01/24 11:30 PM
01/01/24 11:30 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I have a 511 street/strip deal and using the ProGear chain/gears. What is your opinion on the oil slinger in a street/strip package? Some times i use them and some times i dont. I have not seen any issues without. Just thought i would get some opinions on this topic before i put the new billet cover on. Thanks
Re: oil slinger needed or not? [Re: mopar dave] #3201539
01/02/24 12:49 AM
01/02/24 12:49 AM
Out of the State of Confusion
blue_stocker Offline
Use it regardless
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: oil slinger needed or not? [Re: blue_stocker] #3201551
01/02/24 02:46 AM
01/02/24 02:46 AM
Washington
madscientist Offline
Washington
It is an absolutely useless part. Leave it off.
Re: oil slinger needed or not? [Re: blue_stocker] #3201558
01/02/24 03:48 AM
01/02/24 03:48 AM
Originally Posted by blue_stocker
Use it regardless
iagree up
The factory don't put parts in any part of the car that are not needed, do they work twocents
It helps direct slash oil onto the timing chain, doesn't it up work scope
Re: oil slinger needed or not? [Re: madscientist] #3201559
01/02/24 03:50 AM
01/02/24 03:50 AM
Pure dee baloney sauce down twocents scope work
Re: oil slinger needed or not? [Re: Cab_Burge] #3201564
01/02/24 08:40 AM
01/02/24 08:40 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I am going to agree with the useless thing. There are 10's of millions of chevy (and others for that mater) that don't use them.
However I alway use it if I have it.
Re: oil slinger needed or not? [Re: B1MAXX] #3201574
01/02/24 10:13 AM
01/02/24 10:13 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
All the guys running gear drives cannot use them, as the slinger will contact the idler. I have seen no issues NOT running the slinger in my combo, but if you can run it with your timing set, why not throw it on there.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: oil slinger needed or not? [Re: 19swinger70] #3201578
01/02/24 10:25 AM
01/02/24 10:25 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I thought the purpose was to keep oil away from the front seal. Anyway, it rubbed on my aluminum cover - even after I trimmed the lip off. So its gone.
Re: oil slinger needed or not? [Re: Stanton] #3201582
01/02/24 10:57 AM
01/02/24 10:57 AM
Mt Morris Michigan
Mt Morris Michigan
I can see its total purpose on a high milage car. My motors rarely see 10,000 miles before i tear them done and build something else. The slinger i just removed was bubbing on the chain, but only on one half of the slinger. Never seen this. It looks as if it was installed cocked in there and that would be difficult with the ATI damper pressed against it. Not sure what was going on there, but i think i might leave the slinger out this time.
Re: oil slinger needed or not? [Re: mopar dave] #3201584
01/02/24 11:01 AM
01/02/24 11:01 AM
an8sec70cuda Offline
I don't use them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: oil slinger needed or not? [Re: an8sec70cuda] #3201594
01/02/24 11:33 AM
01/02/24 11:33 AM
Mt Morris Michigan
Mt Morris Michigan
Only thing i can figure is the cam had an extra amount of forward movement using a factory chain cover, but then again, why would it only rub half of the slinger? I will be installing one of Andys billet chain covers. Anyone know if Andys covers come with seal and gaskets?
Re: oil slinger needed or not? [Re: mopar dave] #3201618
01/02/24 12:46 PM
01/02/24 12:46 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I’m 90% sure I forgot to put it back on one time, I was worried about the front seal leaking but I don’t recall any problems shruggy Mine looks worse than the one you got there, I think it happens when the damper is installed with the crank bolt and the damper doesn’t clamp down tight/fully seated twocents
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: oil slinger needed or not? [Re: metallicareload] #3201632
01/02/24 01:13 PM
01/02/24 01:13 PM
Mt Morris Michigan
Mt Morris Michigan
Could be. The dampener was almost touching the stock cover on the last install. I think Andys cover is much thicker and damper may touch this time. I will leave the slinger out just in case.
Re: oil slinger needed or not? [Re: Cab_Burge] #3201635
01/02/24 01:23 PM
01/02/24 01:23 PM
Washington
Washington
Just like drip tabs and the idiotic bolt with a hole in it, the slinger does NOTHING. It was a bean counters answer to other issues.
Throw that [censored] in the garbage. All of it. If you want more oil on the timing set, drill a hole in the cam retaining plate and go.
Re: oil slinger needed or not? [Re: madscientist] #3201654
01/02/24 01:53 PM
01/02/24 01:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I pulled my small block down with a few thousand miles on it a couple of years ago and the chain was thrashed. I had forgotten to put a drilled bolt into the normal spot, I also didn't put a slinger on there but I didn't normally run one anyways. So when I went back together with it I drilled the bolt, put the drip thing on, and used a slinger to cover all of the bases. I ran it several more years and another several thousand miles and a good amount of racing. When I changed cams the chain was in the best shape it had ever been in during a teardown. So I will buy into at least one of those making a difference.
68 Barracuda Formula S 340
Re: oil slinger needed or not? [Re: Bad340fish] #3201661
01/02/24 02:04 PM
01/02/24 02:04 PM
I'm pretty sure the main purpose of the slinger is to make sure oil from the pan does not flood the timing cover seal under really hard sudden stops work shruggy
The newer dual lip seals help a bunch also, unlike the OEM single lip seals shruggy work
Re: oil slinger needed or not? [Re: madscientist] #3201674
01/02/24 02:31 PM
01/02/24 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And what would those "issues" be? Since one job of a bean counter is to keep track of expenses, why install a ten-cent part in millions of applications that eventually adds up to tens of thousands of dollars?
Re: oil slinger needed or not? [Re: John_Kunkel] #3201755
01/02/24 05:36 PM
01/02/24 05:36 PM
moparx Offline
moparx  Offline
i have pulled apart original engines that didn't have it, small and big block alike, with no leakage from the front seal, so who knows ?
i have also forgot to install them in a few engine builds, and there were no cover leaks as well.
if i had one, and the front cover fit using it, i would install it.
just my life experience.
your mileage will vary.
beer
Re: oil slinger needed or not? [Re: John_Kunkel] #3201763
01/02/24 06:00 PM
01/02/24 06:00 PM
Washington
Washington
They wanted to keep oil leaks down. It was a cheap, easy way to do it. The bolt and the drip tab do nothing. Oil weeping out of a bolt hole doesn’t put enough oil on the timing set to matter.
Again, warranty money.
Re: oil slinger needed or not? [Re: mopar dave] #3201808
01/02/24 08:53 PM
01/02/24 08:53 PM
AndyF Online content
AndyF  Online Content
I always install an oil slinger if it is available and if it fits. It sometimes doesn't fit with performance parts. Probably not necessary on a performance engine but I'd always use one on a street rebuild.
