Re: oil slinger needed or not?
[Re: blue_stocker]
#3201551
01/02/24 02:46 AM
01/02/24 02:46 AM
Posts: 4,457 Washington
madscientist
Washington
It is an absolutely useless part. Leave it off.
[Re: B1MAXX]
#3201574
01/02/24 10:13 AM
01/02/24 10:13 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
All the guys running gear drives cannot use them, as the slinger will contact the idler. I have seen no issues NOT running the slinger in my combo, but if you can run it with your timing set, why not throw it on there.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: mopar dave]
#3201584
01/02/24 11:01 AM
01/02/24 11:01 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
[Re: mopar dave]
#3201618
01/02/24 12:46 PM
01/02/24 12:46 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I’m 90% sure I forgot to put it back on one time, I was worried about the front seal leaking but I don’t recall any problems Mine looks worse than the one you got there, I think it happens when the damper is installed with the crank bolt and the damper doesn’t clamp down tight/fully seated
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Cab_Burge]
#3201635
01/02/24 01:23 PM
01/02/24 01:23 PM
madscientist
Washington
Just like drip tabs and the idiotic bolt with a hole in it, the slinger does NOTHING. It was a bean counters answer to other issues. Throw that [censored] in the garbage. All of it. If you want more oil on the timing set, drill a hole in the cam retaining plate and go.
[Re: madscientist]
#3201654
01/02/24 01:53 PM
01/02/24 01:53 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I pulled my small block down with a few thousand miles on it a couple of years ago and the chain was thrashed. I had forgotten to put a drilled bolt into the normal spot, I also didn't put a slinger on there but I didn't normally run one anyways. So when I went back together with it I drilled the bolt, put the drip thing on, and used a slinger to cover all of the bases. I ran it several more years and another several thousand miles and a good amount of racing. When I changed cams the chain was in the best shape it had ever been in during a teardown. So I will buy into at least one of those making a difference.
68 Barracuda Formula S 340
[Re: madscientist]
#3201674
01/02/24 02:31 PM
01/02/24 02:31 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
And what would those "issues" be? Since one job of a bean counter is to keep track of expenses, why install a ten-cent part in millions of applications that eventually adds up to tens of thousands of dollars?
[Re: John_Kunkel]
#3201755
01/02/24 05:36 PM
01/02/24 05:36 PM
Posts: 19,535 north of coder
moparx
i have pulled apart original engines that didn't have it, small and big block alike, with no leakage from the front seal, so who knows ? i have also forgot to install them in a few engine builds, and there were no cover leaks as well. if i had one, and the front cover fit using it, i would install it. just my life experience. your mileage will vary.
[Re: John_Kunkel]
#3201763
01/02/24 06:00 PM
01/02/24 06:00 PM
madscientist
Washington
And what would those "issues" be? Since one job of a bean counter is to keep track of expenses, why install a ten-cent part in millions of applications that eventually adds up to tens of thousands of dollars? They wanted to keep oil leaks down. It was a cheap, easy way to do it. The bolt and the drip tab do nothing. Oil weeping out of a bolt hole doesn’t put enough oil on the timing set to matter. Again, warranty money.
