413 block sonic test #3200656
12/29/23 12:36 PM
12/29/23 12:36 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Wondering if anyone has checked the wall thickness on a 72 413 industrial block or maybe it’s a motor home block? Any difference between the two? Has a front sump pan and small diameter but way thicker HB (like a Hemi balancer), dished pistons.
Thanks.
Re: 413 block sonic test [Re: cudaman1969] #3200736
12/29/23 05:15 PM
12/29/23 05:15 PM
I have one(1972 also) I built for my 1963 Fury, I'm going to tell the local streeters it is and old 413 industrial truck motor that runs pretty good devil 4.150 stroke, 7.100 long BB chevy type I beam rods, 440 Spurce heads and RPM inatke with a 850 CFM Pro System double pumper, I had it bore to 4.250 after sonic testing it, I wanted some cylinder wall left for future use if needed luck I think I could have had it bore to 4,320 safely but maybe not, that was a long time ago and I haven't went out to the shop to see if I still have that sonic sheet or not confused
Re: 413 block sonic test [Re: cudaman1969] #3200822
12/30/23 12:57 AM
12/30/23 12:57 AM
AndyF Offline
AndyF  Offline
413 blocks are not usually very thick although I have heard of some 413 blocks that were made from 426 cores. Not sure that is true or not. The typical 413 engine was just like any other Mopar engine cast in the day, that is, they usually suck. The Mopar casting plants had poor quality control so there is usually a fair amount of cores shift. One side of the cylinders will be great, the other side thin. Almost every Mopar block I've ever tested has core shift.
Mopar blocks aren't as bad as Ford blocks, but they aren't great. Best factory blocks are Chevy big blocks. I've never seen a standard bore Chevy big block that was too thin for performance use. Most Ford blocks are too thin for performance use while roughly 50% of all Mopar blocks are too thin.
Re: 413 block sonic test [Re: AndyF] #3200831
12/30/23 01:39 AM
12/30/23 01:39 AM
PA
Scully Offline
Scully  Offline
PA
Many early industrial 413 blocks are over .300" thick before boring which is why they are typically used for NHRA stock 426s. Some mid 60s 383 blocks I have and my 58 350 are well into the high .200"s and low .300"s. I don't think the 70s 413s are quite as consistently thick. The standard 413s are quite thin with the exception of the 1964 2205897 block which was also used for the 426 street wedge as well as a few Max Wedges.
Re: 413 block sonic test [Re: cudaman1969] #3200840
12/30/23 03:29 AM
12/30/23 03:29 AM
NY
B1duster Offline
B1duster  Offline
NY
I have a 72, 71 cast date, industrial 413 block I got from a local guy. It’s 4.23 bore with JE pistons. It’s supposed to be very thick and could go to 4.32. I just got a new Molnar 3.75 -2.2 crank and 6.76 2.2 Molnar rods, stealth heads, A&A max wedge intake and repro max ex manifolds. Only 421 cubes
Re: 413 block sonic test [Re: AndyF] #3200866
12/30/23 10:12 AM
12/30/23 10:12 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What? realcrazy
Not buying this either. 460/429's are very good blocks in my opinion.
The only two engines I have seen with split bores was a BBC, and a BBM
Re: 413 block sonic test [Re: B1MAXX] #3200892
12/30/23 12:22 PM
12/30/23 12:22 PM
fredericksburg,va
fredericksburg,va
Just got this from Al Corda hope it comes out ok. 413 block
Re: 413 block sonic test [Re: cudaman1969] #3200991
12/30/23 07:04 PM
12/30/23 07:04 PM
Which block is it, industrial or passenger car?
They are definitely different thickness castings scope work
Re: 413 block sonic test [Re: Cab_Burge] #3201008
12/30/23 09:34 PM
12/30/23 09:34 PM
fredericksburg,va
fredericksburg,va
Not sure but I’m thinking industrial, right thick on most cylinders at top .250 to .300+. Even at .120 over (426 + .060) still a lot of wall left
Re: 413 block sonic test [Re: cudaman1969] #3201043
12/31/23 12:48 AM
12/31/23 12:48 AM
PA
Scully Offline
Scully  Offline
PA
The last regular 413 blocks were made in 1965, Al used the industrial 413s at some point in his 426 Stockers unless he had some unbored 440s or 426 marine blocks.
Re: 413 block sonic test [Re: Scully] #3201063
12/31/23 07:43 AM
12/31/23 07:43 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
I can see the 413 truck engines being thicker 66 and up. There's a good chance that they were cast using 440 molds.
Angry white pureblood male
Re: 413 block sonic test [Re: ruderunner] #3201180
12/31/23 03:46 PM
12/31/23 03:46 PM
I'm almost positive those two molds are not the same due to the added reenforcing ribs added onto the outside of the industrial 413 blocks scope work
Re: 413 block sonic test [Re: ruderunner] #3201184
12/31/23 04:07 PM
12/31/23 04:07 PM
PA
Scully Offline
Scully  Offline
PA
The thickest 413 I have came out of a 1963 Dodge tractor C 1000, it's in my race car now.
Re: 413 block sonic test [Re: Scully] #3201304
01/01/24 12:19 AM
01/01/24 12:19 AM
fredericksburg,va
fredericksburg,va
Out of curiosity I went to check casting numbers on the 413, NONE other than date. Never saw that before?
Re: 413 block sonic test [Re: cudaman1969] #3201587
01/02/24 11:10 AM
01/02/24 11:10 AM
an8sec70cuda Offline
The '73 industrial 413 block I have isn't crazy thick. I can't recall the thickness from memory, but I wouldn't go past .060" or .070" over. I checked it after hearing about how they were really thick and would easily go to 4.320". Not true w/ the one I have.
CHIP
'06 GMC 2500HD LBZ Duramax
