Page 1 of 3 1 2 3
Throttle cable measurement #3201165
12/31/23 02:54 PM
12/31/23 02:54 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm trying to figure out what throttle cable I need. I have a big block now in my 69 Dart with an Edelbrock Performer RPM intake, Holley 850 carb. and a Mancini high rise throttle bracket. The car was originally a 225 slant. The 225 cable is way too long so I tried a couple of other cables I have in my spare parts but they are both too long as well. One from a small block Dart (not sure if 2 or 4 bbl) and one from a 71 Charger (not sure what engine). The closest one to fitting is the 71 Charger cable but when I installed it, although everything looked proper under the hood, there is about 2" of extra cable sticking through the firewall at the gas pedal (with the pedal tipped back against the firewall). So I measured the excess and it is exactly 2". The cable overall length from the hole in the link that attaches to the throttle pin to the little ball that attaches to the gas pedal is 21" so it looks like I need a 19" overall length cable So, I've been shopping for a cable but when I see the lengths posted, I'm not sure if those are overall length like I was measuring or the length from the carb to the firewall. Does anyone know how those advertised measurements are taken? Also, if anyone happens to know what cable I need please let me know.
Re: Throttle cable measurement [Re: 6PAX] #3201173
12/31/23 03:28 PM
12/31/23 03:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Mancini has them listed by measurement.
Re: Throttle cable measurement [Re: NITROUSN] #3201183
12/31/23 03:56 PM
12/31/23 03:56 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I already looked there. Nothing for a big block A-body.
Re: Throttle cable measurement [Re: 6PAX] #3201188
12/31/23 04:23 PM
12/31/23 04:23 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
ATP Y161
19.25" according to ATP, square hole
https://atpautomotive.com/accelerator-cable-y-161
ATP Y156
19.5" according to ATP, round hole
https://atpautomotive.com/accelerator-cable-y-156
Closest I can find, Rock auto has them if you can't get them local.
Re: Throttle cable measurement [Re: Sniper] #3201201
12/31/23 05:11 PM
12/31/23 05:11 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Originally Posted by Sniper
ATP Y161
ATP Y156
I need the round hole style so I checked the ATP Y156. It doesn't list a 383 Dart as being one of the applications for it. This is why I was wondering how the measurements posted are taken. Plus, 19.5" is still a little too long unless there is some way of mounting the cable to accommodate the extra length.
Re: Throttle cable measurement [Re: 6PAX] #3201220
12/31/23 07:01 PM
12/31/23 07:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They don't list anything that old in their catalog. I dug onto my 69 parts manual, the pn for a 69 Dart with a 4bbl 383 is 2899337
https://www.moparmall.com/MoPar-PN-2899337-Throttle-Cable-p/808-398.htm
Re: Throttle cable measurement [Re: 6PAX] #3201230
12/31/23 08:18 PM
12/31/23 08:18 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
ATP Y161
ATP Y156
Your cable may actually need to be longer than a stock 383 dart. The Performer RPM is significantly taller than stock iron. Also you never said whether you have a B or RB engine. 440 is taller than 383.
Do you have the mopar linkage adapter on the 850 holley? Something is weird here. If the cable housing is attached to the firewall and adjusted properly at the bracket ( you do have the correct bracket?) then it should work.
Last edited by GomangoCuda; 12/31/23 08:37 PM. Reason: because something else came to mind.
Re: Throttle cable measurement [Re: 6PAX] #3201231
12/31/23 08:19 PM
12/31/23 08:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: Throttle cable measurement [Re: NITROUSN] #3201254
12/31/23 10:10 PM
12/31/23 10:10 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Since your engine is already not stock, have you considered just buying a universal cable and cutting it to length? I've used cables similar to this on on my 440 Dart and my '73 360 truck and they work great.
Re: Throttle cable measurement [Re: Exit1965] #3201268
12/31/23 10:43 PM
12/31/23 10:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I for one DESPISE those finger pricking POS's ( No offense meant to you wink
I would suggest using the existing cable trimming the excess length off and swaging a new end on or use a brrel clamp likely available at you're local hardware store or lawn mower, bicycle shop LINKY
Re: Throttle cable measurement [Re: GomangoCuda] #3201278
12/31/23 10:56 PM
12/31/23 10:56 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
It's a 400 block and I do have the adapter.and a Mancini high rise bracket. As I mentioned, using the 71 Charger cable, when attached to the carb., and clamped down in the bracket it runs to the firewall and looks like I believe it should (not too short, not too long). But, when I got under the dash to connect it to the pedal, the actual inner cable sticks out about 2" past the little hole it goes through in the pedal arm (with the pedal in the full up position).
Re: Throttle cable measurement [Re: TJP] #3201279
12/31/23 11:04 PM
12/31/23 11:04 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I thought about shortening the cable but wasn't sure on how to replace the little ball on the end (swaging?). I never saw the cable stop before that is shown in the link you sent. That it is something I will seriously consider. Thanks for the link.
Re: Throttle cable measurement [Re: 6PAX] #3201310
01/01/24 12:42 AM
01/01/24 12:42 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Attach the cable at the pedal end,pull the slack at the carb end and cut and replace the carb fitting with the pedal heigth set where you want it.
Re: Throttle cable measurement [Re: stumpy] #3201334
01/01/24 07:39 AM
01/01/24 07:39 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Have you adjusted the cable for WOT? Pedal on floor and carb full open?
The Pedal will end up wherever it ends up at closed throttle.
Angry white pureblood male
Re: Throttle cable measurement [Re: TJP] #3201340
01/01/24 08:34 AM
01/01/24 08:34 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Superglue on the able where you want to cut it usually keeps it together and prevents finger pricks.
Re: Throttle cable measurement [Re: Sniper] #3201512
01/01/24 10:54 PM
01/01/24 10:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I actually thought about that but haven't and probably won't have the chance as I'm pretty much done working on other peoples cars wink Thanks for the suggestion beer
Re: Throttle cable measurement [Re: 6PAX] #3201516
01/01/24 11:10 PM
01/01/24 11:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
It will also allow you to play with the adjustment until you have WOT and an agreeable pedal height as mentioned. I would also make sure there is adequate adjustment and the cable clamp on the manifold. beer
Re: Throttle cable measurement [Re: GomangoCuda] #3201599
01/02/24 11:57 AM
01/02/24 11:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
ATP Y161
ATP Y156
He will definitely want one that is longer than the stock BB a body cable. I saw a listing I thought somewhere showing the A body length , it's not on the mancini chart though .
Re: Throttle cable measurement [Re: 6PAX] #3201601
01/02/24 12:00 PM
01/02/24 12:00 PM
JohnRR Offline
JohnRR  Offline
71 charger cable has a square plastic end at the firewall , not the steel round one,I thought ?
Re: Throttle cable measurement [Re: JohnRR] #3201602
01/02/24 12:04 PM
01/02/24 12:04 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I seem to recall some swap where the Slant 6 cable was the "hot tip", but they're pretty long...
Page 1 of 3 1 2 3
