Re: Throttle cable measurement
[Re: 6PAX]
#3201220
12/31/23 07:01 PM
12/31/23 07:01 PM
Posts: 6,306 nowhere
Sniper
nowhere
I need the round hole style so I checked the ATP Y156. It doesn't list a 383 Dart as being one of the applications for it. This is why I was wondering how the measurements posted are taken. Plus, 19.5" is still a little too long unless there is some way of mounting the cable to accommodate the extra length.
They don't list anything that old in their catalog. I dug onto my 69 parts manual, the pn for a 69 Dart with a 4bbl 383 is 2899337 https://www.moparmall.com/MoPar-PN-2899337-Throttle-Cable-p/808-398.htm
[Re: 6PAX]
#3201230
12/31/23 08:18 PM
12/31/23 08:18 PM
Posts: 4,755 Moved to N.E. Tennessee
GomangoCuda
I need the round hole style so I checked the ATP Y156. It doesn't list a 383 Dart as being one of the applications for it. This is why I was wondering how the measurements posted are taken. Plus, 19.5" is still a little too long unless there is some way of mounting the cable to accommodate the extra length. Your cable may actually need to be longer than a stock 383 dart. The Performer RPM is significantly taller than stock iron. Also you never said whether you have a B or RB engine. 440 is taller than 383. Do you have the mopar linkage adapter on the 850 holley? Something is weird here. If the cable housing is attached to the firewall and adjusted properly at the bracket ( you do have the correct bracket?) then it should work.
Last edited by GomangoCuda; 12/31/23 08:37 PM. Reason: because something else came to mind.
[Re: Exit1965]
#3201268
12/31/23 10:43 PM
12/31/23 10:43 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
Since your engine is already not stock, have you considered just buying a universal cable and cutting it to length? I've used cables similar to this on on my 440 Dart and my '73 360 truck and they work great. I for one DESPISE those finger pricking POS's ( No offense meant to you I would suggest using the existing cable trimming the excess length off and swaging a new end on or use a brrel clamp likely available at you're local hardware store or lawn mower, bicycle shop LINKY
[Re: GomangoCuda]
#3201278
12/31/23 10:56 PM
12/31/23 10:56 PM
Posts: 5,653 Detroit area
6PAX
Detroit area
Do you have the mopar linkage adapter on the 850 holley? Something is weird here. If the cable housing is attached to the firewall and adjusted properly at the bracket ( you do have the correct bracket?) then it should work. It's a 400 block and I do have the adapter.and a Mancini high rise bracket. As I mentioned, using the 71 Charger cable, when attached to the carb., and clamped down in the bracket it runs to the firewall and looks like I believe it should (not too short, not too long). But, when I got under the dash to connect it to the pedal, the actual inner cable sticks out about 2" past the little hole it goes through in the pedal arm (with the pedal in the full up position).
[Re: TJP]
#3201279
12/31/23 11:04 PM
12/31/23 11:04 PM
6PAX
Detroit area
I for one DESPISE those finger pricking POS's ( No offense meant to you I would suggest using the existing cable trimming the excess length off and swaging a new end on or use a brrel clamp likely available at you're local hardware store or lawn mower, bicycle shop LINKY I thought about shortening the cable but wasn't sure on how to replace the little ball on the end (swaging?). I never saw the cable stop before that is shown in the link you sent. That it is something I will seriously consider. Thanks for the link.
[Re: stumpy]
#3201334
01/01/24 07:39 AM
01/01/24 07:39 AM
Posts: 5,924 ohio
ruderunner
ohio
Have you adjusted the cable for WOT? Pedal on floor and carb full open?
The Pedal will end up wherever it ends up at closed throttle.
Angry white pureblood male
[Re: TJP]
#3201340
01/01/24 08:34 AM
01/01/24 08:34 AM
Sniper
nowhere
Superglue on the able where you want to cut it usually keeps it together and prevents finger pricks.
[Re: Sniper]
#3201512
01/01/24 10:54 PM
01/01/24 10:54 PM
TJP
Omaha Ne
Superglue on the able where you want to cut it usually keeps it together and prevents finger pricks. I actually thought about that but haven't and probably won't have the chance as I'm pretty much done working on other peoples cars Thanks for the suggestion
[Re: GomangoCuda]
#3201599
01/02/24 11:57 AM
01/02/24 11:57 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
I need the round hole style so I checked the ATP Y156. It doesn't list a 383 Dart as being one of the applications for it. This is why I was wondering how the measurements posted are taken. Plus, 19.5" is still a little too long unless there is some way of mounting the cable to accommodate the extra length. Your cable may actually need to be longer than a stock 383 dart. The Performer RPM is significantly taller than stock iron. Also you never said whether you have a B or RB engine. 440 is taller than 383. Do you have the mopar linkage adapter on the 850 holley? Something is weird here. If the cable housing is attached to the firewall and adjusted properly at the bracket ( you do have the correct bracket?) then it should work. He will definitely want one that is longer than the stock BB a body cable. I saw a listing I thought somewhere showing the A body length , it's not on the mancini chart though .
[Re: 6PAX]
#3201601
01/02/24 12:00 PM
01/02/24 12:00 PM
JohnRR
Do you have the mopar linkage adapter on the 850 holley? Something is weird here. If the cable housing is attached to the firewall and adjusted properly at the bracket ( you do have the correct bracket?) then it should work. It's a 400 block and I do have the adapter.and a Mancini high rise bracket. As I mentioned, using the 71 Charger cable, when attached to the carb., and clamped down in the bracket it runs to the firewall and looks like I believe it should (not too short, not too long). But, when I got under the dash to connect it to the pedal, the actual inner cable sticks out about 2" past the little hole it goes through in the pedal arm (with the pedal in the full up position). 71 charger cable has a square plastic end at the firewall , not the steel round one,I thought ?
