Re: HS rockers on Indy EZ-1 heads ??
[Re: Stanton]
#3201003
12/30/23 08:21 PM
12/30/23 08:21 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I've seen a number of Indy heads set up w/ HS rockers and they always looked like a good combination to me; never heard people complain about the fitment.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Stanton]
#3201037
12/31/23 12:10 AM
12/31/23 12:10 AM
Posts: 3,216 Md.
carnut68
Md.
I have the HS gold version non bushed bought from Mancini, these were apparently a limited version. I have had no problems with them on Indy EZ heads.
America First!
[Re: Cab_Burge]
#3201087
12/31/23 10:48 AM
12/31/23 10:48 AM
Posts: 8,890 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I run HS rockers on my EZ-1 heads with no issues. So they're the standard 40-year-old design for big block Mopars? How is the alignment over the valve tip - do they sit to one side or the other or are they pretty much centered? What about grinding for pushrod clearance - did you have to do much of that? Basically, what did you have to do to make them fit and work properly - if anything?
