Re: 2009 Engine masters
[Re: W5DART66]
#320072
05/16/09 09:30 PM
05/16/09 09:30 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#320073
05/16/09 09:31 PM
05/16/09 09:31 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#320074
05/16/09 09:32 PM
05/16/09 09:32 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#320075
05/16/09 09:33 PM
05/16/09 09:33 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#320076
05/16/09 09:34 PM
05/16/09 09:34 PM
Posts: 1,784 PA
W5DART66
PA
[Re: S/ST 3040]
#320085
05/17/09 10:06 AM
05/17/09 10:06 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Dial indicators are used extensively on snap-gages, throughout the machining industry for tolerances down to at least .0001" It's much quicker and highly accurate. I've used them for years.
The real nice ones yes, but a standard indicator (like the one pictured) is only good down to .0005. The crappiest mics out there are good to .0001. I'm not seeing the logic, I guess it's just faster with a DI...
[Re: W5DART66]
#320087
05/17/09 11:18 AM
05/17/09 11:18 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Brett,
Check your pms.
Todd
RIP Monte Smith
[Re: CokeBottleKid]
#320089
05/18/09 08:01 AM
05/18/09 08:01 AM
it's possible that whatever information you've learned from books doesn't correlate exactly to what actually works for the hands on mechanic. for example, you have to separate accuracy and resolution when it comes to mic's and indicators. a given mic might only read to .001 (i have a couple of Starret's that way)but with great accuracy. an "experienced" user can read that mic to within .0001 the same goes for dial indicators. stretch guages like the one shown are far superior than using a given torque value for critical components like rod bolts.
