Page 1 of 3 1 2 3
2009 Engine masters #320071
05/16/09 09:29 PM
05/16/09 09:29 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Here are some pics of the start of the 2009 SB mopar. Vic Bloomer and I am working on this year. I was not going to do this but I could not sell last years engine and Vic and I had alot of fun. So with some help for vic on new crank,rods and intake here we go again LOL.
Engine will be Bigger this year.
3.792" crank by 4.070" bore (BIG thanks Vic)
11.3to1
I will be making big changes to the heads and intake setup from last years engine.
Re: 2009 Engine masters [Re: W5DART66] #320072
05/16/09 09:30 PM
05/16/09 09:30 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
2
Re: 2009 Engine masters [Re: W5DART66] #320073
05/16/09 09:31 PM
05/16/09 09:31 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
3
Re: 2009 Engine masters [Re: W5DART66] #320074
05/16/09 09:32 PM
05/16/09 09:32 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: 2009 Engine masters [Re: W5DART66] #320075
05/16/09 09:33 PM
05/16/09 09:33 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: 2009 Engine masters [Re: W5DART66] #320076
05/16/09 09:34 PM
05/16/09 09:34 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: 2009 Engine masters [Re: W5DART66] #320077
05/16/09 10:00 PM
05/16/09 10:00 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Funny thing is,every time I see Vic lately,he is on the phone with Brett.I'm glad you guys are doing this again,looking forward to seeing and hearing more about it!
Re: 2009 Engine masters [Re: W5DART66] #320078
05/16/09 10:11 PM
05/16/09 10:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good luck to both of you
Re: 2009 Engine masters [Re: Dunnuck Racing] #320079
05/16/09 10:13 PM
05/16/09 10:13 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Every time? Come on.
Maybe we will bend the needle on that DTS this year.
Re: 2009 Engine masters [Re: S/ST 3040] #320080
05/17/09 01:27 AM
05/17/09 01:27 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
So what are the rules this year? I can't find them any where, cept a few very general ones
Re: 2009 Engine masters [Re: HotRodDave] #320081
05/17/09 08:03 AM
05/17/09 08:03 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Looks good, but can someone answer me why they use a dial indicator instead of a specialized mic? I've never understood this unless for some reason you wanted to measure stretch while you were torquing, which I don't see how you can in that setup...
Re: 2009 Engine masters [Re: CokeBottleKid] #320082
05/17/09 08:17 AM
05/17/09 08:17 AM
S/ST 3040 Offline
S/ST 3040  Offline
Dial indicators are used extensively on snap-gages, throughout
the machining industry for tolerances down to at least .0001" It's
much quicker and highly accurate. I've used them for years.
Re: 2009 Engine masters [Re: S/ST 3040] #320083
05/17/09 08:37 AM
05/17/09 08:37 AM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
Good luck guys! Where and when is the contest this year?
Steve
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: 2009 Engine masters [Re: StrokedW7] #320084
05/17/09 09:21 AM
05/17/09 09:21 AM
S/ST 3040 Offline
S/ST 3040  Offline
Re: 2009 Engine masters [Re: S/ST 3040] #320085
05/17/09 10:06 AM
05/17/09 10:06 AM
Detroit, MI
Detroit, MI
The real nice ones yes, but a standard indicator (like the one pictured) is only good down to .0005. The crappiest mics out there are good to .0001. I'm not seeing the logic, I guess it's just faster with a DI...
Re: 2009 Engine masters [Re: CokeBottleKid] #320086
05/17/09 10:27 AM
05/17/09 10:27 AM
412 SB Duster Offline
Why not just good luck or something instead of trying to
Good luck this yr
Al
Re: 2009 Engine masters [Re: W5DART66] #320087
05/17/09 11:18 AM
05/17/09 11:18 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Brett,
Check your pms.
Todd
RIP Monte Smith
Re: 2009 Engine masters [Re: 412 SB Duster] #320088
05/18/09 07:43 AM
05/18/09 07:43 AM
BPE Offline
BPE  Offline
I know Vic had a blast last year and I can't wait to hear how it goes. GOOD LUCK
Rod
Re: 2009 Engine masters [Re: CokeBottleKid] #320089
05/18/09 08:01 AM
05/18/09 08:01 AM
it's possible that whatever information you've learned from books doesn't correlate exactly to what actually works for the hands on mechanic.
for example, you have to separate accuracy and resolution when it comes to mic's and indicators. a given mic might only read to .001 (i have a couple of Starret's that way)but with great accuracy. an "experienced" user can read that mic to within .0001 the same goes for dial indicators. stretch guages like the one shown are far superior than using a given torque value for critical components like rod bolts.
Re: 2009 Engine masters #320090
05/19/09 09:05 PM
05/19/09 09:05 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
Brett- I didn't know you had the bottom end together already. Definitely much farther ahead than you were last year!
Page 1 of 3 1 2 3
