Who makes a 69 lift off hood with a taller scoop? #3200000
12/25/23 05:09 PM
12/25/23 05:09 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Looking for a lift off hood for my 69 GTX that has about a 6 inch tall scoop.
I've seen some at tracks, but when I Google seached, all I found was the standard type.
I ask because I run a Victor with a 1/2 shear plate. When I run the car without the hood it picks up over 1/2 MPH and 5/10s at the eighth mile. I have a shearplate/ 1 inch open spacer combo that was worth 9 HP and 16 ft lbs on a chassis dyno that I want to run down the track.
Any help is appreciated.
Re: Who makes a 69 lift off hood with a taller scoop? [Re: mercman1] #3200043
12/26/23 06:41 AM
12/26/23 06:41 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Glasstek will make a hood with a 6" scoop.
69 GTX 68 Road Runner
Re: Who makes a 69 lift off hood with a taller scoop? [Re: JERICOGTX] #3200046
12/26/23 09:02 AM
12/26/23 09:02 AM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Jerico GTX, You the man. Thank you!
Re: Who makes a 69 lift off hood with a taller scoop? [Re: mercman1] #3200050
12/26/23 10:04 AM
12/26/23 10:04 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looks like the tallest scoop Glasstek has is 5".
Re: Who makes a 69 lift off hood with a taller scoop? [Re: JERICOGTX] #3200175
12/26/23 10:53 PM
12/26/23 10:53 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
VFM makes them too
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
