Page 5 of 5 1 2 3 4 5
Re: Street hemi build to stroke or not to stroke [Re: INTMD8] #3198778
12/19/23 11:14 PM
12/19/23 11:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’m stroking both of mine 4.15 x 4.31 iron head in the 66 Belvedere and 4.5 x 4.56 aluminum head in the 64 Savoy, both with 12.5 pistons. If I have to put 15 gallons of race fuel in them to go to the Queen so what, a dang meal for the wife and I is an easy $50 now and the smell of race gas is so sweet.
Re: Street hemi build to stroke or not to stroke [Re: INTMD8] #3198781
12/19/23 11:21 PM
12/19/23 11:21 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by INTMD8
Originally Posted by Hemi_Joel
If you are going to be a bear, why not be a grizzly? I'd stroke that Hemi, get a minor port job on the heads, 3/4 roller cam, 10.5:1 compression.
Look, the 425-460 horse of a stock Hemi was a big deal in 1966-1967. Today, it's nothing. Don't embarrass the Hemi legend by building an engine that won't keep up with the LS.
The factor of embarrassment is based on the stroke?
If so I'll put 10k up against this car heads up no matter what displacement it ends up at. smile
No. It's the whole package. He says it is a purely street car, not a race car. But inevitably, he will be rolling down the freeway at 70 and some other hot car is going to pull up along side and floor it. He will be a lot less likely to be embarrassed if he has 650 horse under the hood than 450. And it is a whole lot easier and better street mannered to make 650 horse with the extra stroke.
Re: Street hemi build to stroke or not to stroke [Re: Hemi_Joel] #3198786
12/20/23 12:12 AM
12/20/23 12:12 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes. Mine is purely street not race.
Re: Street hemi build to stroke or not to stroke [Re: Hemi_Joel] #3198880
12/20/23 02:15 PM
12/20/23 02:15 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I really don't care if I win or lose in a situation like this. The car is more a bucket list to own for me than anything combined with a nice cruiser. I can smash every one in a great while just for grins. NOT something for street creds or bragging rights in any way shape or form
Im probably at least a year away, maybe more for giving this real serious thoughts on how to actually build ,,,or not.
I truly understand the desire to go that route. But Im simply not the kid I used to be that wanted a top level fast car like that.
That said, If I pull it down and happen to find a crank issue . Then I will give some serious thoughts to build it with a little more ummmmph
Re: Street hemi build to stroke or not to stroke [Re: Twostick] #3198936
12/20/23 06:16 PM
12/20/23 06:16 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Originally Posted by Twostick
Originally Posted by topside
I don't get the 9.0:1 Street Hemi idea - the chamber is not that sensitive to octane.
That's a fundamental reason Chrysler introduced it for the '51 models.
I ran 10.8:1 in mine with iron heads on Calif 91 and it never rattled.
Granted, the cam had some overlap that bled off a bit of CR, but it had a fairly aggressive curve, 36 total, + vac advance.
I built my wedge that way. 9:1, 500 hp, 600 ft/lbs on 87 regular and more than enough bottom end torque to launch a 4800 lb New Yorker around with authority with 3.23 gears. 4.15 stroke.
He said it's a street car and it sounds like he drives it further than the local Dairy Queen. I'd build a 9:1 4.25 stroke tractor motor with a power brake friendly cam profile and enjoy the no drama able to drive it cross country street manners that can still roast tires or dust a 911 on a 60 mph roll on.
Kevin
iagree
Re: Street hemi build to stroke or not to stroke [Re: MarkZ] #3199116
12/21/23 01:49 PM
12/21/23 01:49 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Daily drove a '69 Hemi Roadrunner for several years. Small cam, headers, electronic ignition. Super Track Pack 4-speed car. I never felt like it was lacking for power. Just a strong, cool cruising machine. Wish I still had it. twocents
Re: Street hemi build to stroke or not to stroke [Re: Hemi_Joel] #3199566
12/23/23 06:21 AM
12/23/23 06:21 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I'm sorry Joel, I apologize. I took this the wrong way the other day but I understand what you're saying and agree.
Re: Street hemi build to stroke or not to stroke [Re: 360view] #3199571
12/23/23 08:25 AM
12/23/23 08:25 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
No replacement for cubic displacement.
Can’t be sure what age I was when I first heard that
but probably before age 10.
Great love of stroke shines through in this thread.
No love of the wonder of nitrous has popped up -yet.
How engines work is nearly magic,
and the closer you look at little details the more “wow, that’s amazing” moments happen.
Another thing that comes out is the “winter dreaming” of what future tinkering one might do.
Re: Street hemi build to stroke or not to stroke [Re: 360view] #3199640
12/23/23 02:36 PM
12/23/23 02:36 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, question.
On these large stroker engines are headers a requirement
What about head work or cam profile , stock intake and carb setups etc etc
Torque conv upgrades, rear axle ?
( mine is an auto with about a 2800/3000 stall and 3.54 dana )
I'll be honest, Im not a big fan of the convertor , IMO takes far too much throttle to get it moving, especially cold.
Re: Street hemi build to stroke or not to stroke [Re: gtx6970] #3199709
12/23/23 07:19 PM
12/23/23 07:19 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
And more torque from more inches will only make the converter seem more sluggish on the street.
I fought this issue on my 540. It was just too 'mushy' below 3,500. I wanted a snappier, crisper response at low engine speeds. Like when I was cruising and driving around town. I tried PTC twice, but I wasn't happy with the results. I ended up sending it to UCC, back when Lenny was still there. He opened the converter, called me and said there wasn't anything else off the shelf he could do to tighten it up any more.
BUT! He had a couple of tweeks he could make and had some suggestions for me to do on my end. Now that helped a noticeable amount. The car moves off better and is almost as crisp and responsive as stock. And it cost less than $350. Lenny's the man! Or was the man, anyway.
Master, again and still
Re: Street hemi build to stroke or not to stroke [Re: gtx6970] #3199730
12/23/23 10:09 PM
12/23/23 10:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Originally Posted by gtx6970
Ok, question.
Andy did it. I thought there was a magazine article somewhere for it. Found a thread on FABO.
https://www.forabodiesonly.com/mopar/threads/sniper-on-a-big-block-stroker.409379/
Re: Street hemi build to stroke or not to stroke [Re: gtx6970] #3200505
12/28/23 02:59 PM
12/28/23 02:59 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
I have a stoke bore with a 4.15" crank. From what I remember the cost of the rotating assembly for the 4.15" stroke was the same as the stock 3.75" stroke. I was also told that a stock stroke 426 would have less low end torque than the 440 I was replacing it with. I went with the 472 instead of the 528 because the 528 required a siamesed block and I didn't want to give up any cooling capacity for hot days.
Re: Street hemi build to stroke or not to stroke [Re: gtx6970] #3200514
12/28/23 04:22 PM
12/28/23 04:22 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Ok, question.
We did 1 3/4" headers and they work fine on my 505. I also use a 2800 rated 11" stall converter that works great with a 3.54 gear.
You really should have some type of head work done to take advantage of the larger stroke. I tried using an 8 3/4 and broke it in short order. Put a Dana or 9" in and never look back.
'63 Dodge 330
11.19 @ 121 mph
