Edelbrock big block heads; $900 #3198454
12/18/23 07:54 PM
12/18/23 07:54 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Master, again and still
Re: Edelbrock big block heads; $900 [Re: DaveRS23] #3198458
12/18/23 08:03 PM
12/18/23 08:03 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
He says issues in one cylinder, but around the plug area, looks like it was welded?
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Edelbrock big block heads; $900 [Re: oldjonny] #3198485
12/18/23 10:45 PM
12/18/23 10:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agrred and I wouldn't run em twocents
Re: Edelbrock big block heads; $900 [Re: TJP] #3198487
12/18/23 10:54 PM
12/18/23 10:54 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Dang, the cylinder looks Like it’s going to need a few hundred bucks to fix it. Unless you did your own machine work, would be better off with a new set.
Re: Edelbrock big block heads; $900 [Re: migsBIG] #3198499
12/18/23 11:50 PM
12/18/23 11:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It was just “detonation”. up
If weld was ok, would have some promise. But should have welded up some of the chamber cuts. I’d be afraid of smoothing those down and loosing the cc’s in that chamber.
They do have a valve job. Some nefarious flipper will buy them and stick them on a “compete rebuilt motor” on Facebook from a private party. Unsuspecting buyer.
