Roller Lifters for a 572/ 604 Hemi
#3198040
12/16/23 07:26 PM
12/16/23 07:26 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
What is every one running with theie Hemi that has a ton of Valve Spring pressure for a Roller Lifter. Friend had his motor come apart because or the liftert. He is going to the Grouved lifter at an Extreme cost and machine work to his New BK Block. Since getting roller lifters rebuild seem to be a no go what lifters do people like more than others. I know what brand that came apart is his hemi but want to hear from others before stating who made them. Also another wanted me to ask, his new hemi with a 650 lift what would be a good roller lifter for his set up, These motor are all 604s or 572s and the seonnd motor is a street cars fo..
1971 HEMI E BODY REGISTRY
Re: Roller Lifters for a 572/ 604 Hemi
[Re: hemicar1971]
#3198043
12/16/23 07:32 PM
12/16/23 07:32 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ray Barton told me Jesel. But I have to ask. How can he have a ton of spring pressure with .650" lift? Curious minds want to know.
2011 Drag Pak Challenger
[Re: AndyF]
#3198075
12/17/23 12:47 AM
12/17/23 12:47 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have Crowers in my Hemi street driven with over .800 lift with no issues after several seasons and hundreds of street miles.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dragula]
#3198110
12/17/23 12:02 PM
12/17/23 12:02 PM
hemicar1971
Chicago Blackhawks
The 604 made 1365hp and it is a guess but the lift is around and inch 1000 or a little more.Spring pressures are huge and this motor came apart first time out. It is also going back to the builder to be replaced, The lifter he is now going to use are not Cheap near twice the money are the bar lifters and have a key way. The person with the 650 lift knows his spring pressures will be no were near the 604. He wants to buy a very good roller lifter that will last on a street driven motor with very few problems or have to be looked at during the year. Since Roller lifter Companies stopped offering a rebuild of their roller lifters he wants something that will last.
[Re: Dragula]
#3198136
12/17/23 01:38 PM
12/17/23 01:38 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
So he is going to a Jesel Keyway lifter, should have likely had them in the first place. And probably a larger diameter and wheel. Having said that Isky stuff works very well for most applications. I have Jesels and Isky stuff in all my engines.
[Re: Al_Alguire]
#3198182
12/17/23 05:41 PM
12/17/23 05:41 PM
hemicar1971
Chicago Blackhawks
My understanding the person with the 604 has never had a Roller Lifter failure befoe. We wanted to take a look to see the exact problem, but he called the builder and packed the motor up in a crate and sent it to him because he wanted to see what went on. Good call by the builder. The guy with the 604 has had 540 572 in his cal over the years and never had any problems. We hope to find out in the future just what happened. The guy with the 650 cam the hemi is a 572 street car and just wants things to work and stay together without living under the hood.
[Re: hemicar1971]
#3198332
12/18/23 09:58 AM
12/18/23 09:58 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
FWIW...I run Isky Red Zone solid roller lifters with needle bearings. The bushed lifters weren't an option when I bought these. My cam is only .672"/.651" lift, but they've been flawless since 2006. Street/strip motor.
