Motor Trend 572
#3197760
12/15/23 05:02 PM
12/15/23 05:02 PM
Posts: 3,023 NY
B1duster
NY
Re: Motor Trend 572
[Re: B1duster]
#3197804
12/15/23 08:00 PM
12/15/23 08:00 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Nice ! very similar spec to mine, but we are at 12.5:1 and a T/R. We have maybe a little more hp but not much.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Motor Trend 572
[Re: Tig]
#3197810
12/15/23 08:36 PM
12/15/23 08:36 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
My experience with the dynoo at Westech is that is VERY VERY happy...While it should make a nice combo dont expect 900HP
Re: Motor Trend 572
[Re: Al_Alguire]
#3197813
12/15/23 08:42 PM
12/15/23 08:42 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My experience with the dynoo at Westech is that is VERY VERY happy...While it should make a nice combo dont expect 900HP Typical ragazine dyno test. Used to be 600 horsepower, then 700, then 800, and now 900 lmao 😂
Re: Motor Trend 572
[Re: birdtracker]
#3197832
12/15/23 10:16 PM
12/15/23 10:16 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Andy and Al are spot on. Birdtracker Ya, gotta agree. The specs of the parts don't match the hp numbers posted, so i am skeptical. I would say 850 would be a good number for what little info provided. The track will tell the tail. Allthough i expect it will perform well with that power curve.
Re: Motor Trend 572
[Re: dvw]
#3197914
12/16/23 11:46 AM
12/16/23 11:46 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Those heads won’t make 900hp n/a without a fair amount of rework………. same with the manifold.
You’d think if that had happened, it would have been mentioned.
Re: Motor Trend 572
[Re: fast68plymouth]
#3197966
12/16/23 02:28 PM
12/16/23 02:28 PM
gregsdart
You’d think if that had happened, it would have been mentioned. I got 926 hp out of 440-1 heads, but they were ported extensively, had 2.3 intake valves, and about every trick i could come up with to get there in the rest of the combo. Huge cam, .9 mm rings, wilson ported 3x, 15/1 compression, Terminater 2500 cfm theottle body and methanol, 2 1/8 tube excellent headers and a vacuum pump. 900 hp doesn't just show up easy.
Re: Motor Trend 572
[Re: 440Jim]
#3198568
12/19/23 12:05 PM
12/19/23 12:05 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I agree. Not so good on my 12.5:1 511 either. Had one of Dwayne's flat tappets in it and ran a best of 10.06@134/3400#. Slide rule shows 630hp. I would think the combo would have made at least 700hp. My victors are ported and flowed 356@.700 with a 330cc port. Wish i would have stayed with my earlier plan of using 440-1 now.
