Water manifold #3197740
12/15/23 02:30 PM
12/15/23 02:30 PM
NY
moparmatt0 Offline OP
NY
Looking to change from a csr pump to a inline Stewart on a 572 indy block who makes a manifold for the upper and lower hoses and the temp sender for drag use only thanks for a help
Re: Water manifold [Re: moparmatt0] #3197742
12/15/23 02:37 PM
12/15/23 02:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine are plumbed directly into the water pump outlets on the block. I use the Meziere block adapters for mine. My temp sensor is in the radiator. FWIW I use a Meziere radiator mounted pump. Can take other pics if you like. FWIW Wilson sells water manifolds. They are not cheap and you will still need the block adapters. Also I believe AndyF also sells block adapters.
Not easy to see but they are in there
Re: Water manifold [Re: moparmatt0] #3197750
12/15/23 03:39 PM
12/15/23 03:39 PM
AndyF Offline
AndyF  Offline
I used to make block adapters but I sold the design to Indy. Call them and see if they have some in stock. Last I knew they were still selling them.
Re: Water manifold [Re: AndyF] #3197772
12/15/23 06:07 PM
12/15/23 06:07 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
