head gasket part # #3196916
12/12/23 10:42 AM
12/12/23 10:42 AM
Illinois, USA
superbee69 Offline OP
Illinois, USA
BME aluminum block 4.500 bore & stage 5 heads 11.4 to1 comp, felpro or MLS cometic which one to use
Re: head gasket part # [Re: superbee69] #3196940
12/12/23 11:48 AM
12/12/23 11:48 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Everybody else in the world loves Cometics but I like the Fel-Pro 1104. Amazon has them $42.79 each. I've also bought from walmart.com I'll have to go out in the shop to get the Cometic #.
2011 Drag Pak Challenger
Re: head gasket part # [Re: rickseeman] #3196944
12/12/23 12:02 PM
12/12/23 12:02 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
The Cometics can be had in different thicknesses. The .040" thick is Cometic 426-G1-040-4.500 .040” compressed. Around a million dollars apiece.
Well, that seems wrong it's really C5447-040 that other number I got off of the wrapper.
Re: head gasket part # [Re: rickseeman] #3196947
12/12/23 12:23 PM
12/12/23 12:23 PM
Illinois, USA
Illinois, USA
Thank's Rick This was you'r block I bought and the indy heads are still on the shelf , love your videos very helpful
Re: head gasket part # [Re: superbee69] #3196996
12/12/23 04:46 PM
12/12/23 04:46 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I would go with the Fel Pro in this instance. todd
Re: head gasket part # [Re: sasquatch] #3197009
12/12/23 05:34 PM
12/12/23 05:34 PM
Illinois, USA
Illinois, USA
Then felpro it is ,could you give a reason one over the other. thanks for the info
Re: head gasket part # [Re: superbee69] #3197026
12/12/23 06:47 PM
12/12/23 06:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You don't mention what thickness you're after !!
Re: head gasket part # [Re: Stanton] #3197029
12/12/23 07:05 PM
12/12/23 07:05 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We have seen some water migration issues when using the BMP blocks with the 4.500 bore and Cometic gaskets. Let me be clear. I like and use Cometic style gaskets all the time and I am a dealer for them. BUT in this specific case we use the Fel Pro with good success. Look at the water ports on the block. The water is migrating between the gasket layers. Water ends up in the crank case. Ot happened to us twice on different engines. Todd
