71 Cuda K-member: does it need replacement or... #3195710
12/06/23 02:53 PM
12/06/23 02:53 PM
Alabama
David1971 Offline OP
Alabama
Can it be repaired? I searched the web and I can't find a "how to" on repair.
Thanks,
David
Re: 71 Cuda K-member: does it need replacement or... [Re: David1971] #3195761
12/06/23 06:22 PM
12/06/23 06:22 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I assume your referring to where its pushed in on the left of the center seem, if it was mine I would remove the stabilizer bar & heat it up to the point of glowing red & get behind the dent with a pry bar & work the dent out, you may need to put a block of wood or something inside to give the prybar something to push against, that's what I did for mine but it wasn't quite as bent,
Re: 71 Cuda K-member: does it need replacement or... [Re: David1971] #3195854
12/07/23 10:56 AM
12/07/23 10:56 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
It's banged up pretty good , I worked on one similar to that when it was out of the car using a couple of the holes that are in the top right over it with a steel rod thru the hole , then hid what was there with a repop skid plate , looks like you could use the skidplate to help protect that pan.
