Engine builder in Northeast area? #3193416
11/26/23 03:07 PM
11/26/23 03:07 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
Anyone know someone who rebuild a 440 in the new England area?
Re: Engine builder in Northeast area? [Re: Fern] #3193422
11/26/23 03:54 PM
11/26/23 03:54 PM
CT & ME
Flat-Tappet Offline
Flat-Tappet  Offline
CT & ME
Give Carlquist Competition engines, Watertown CT a call.
Bill C has built several SBF and BMW engines for me. I know he has built some stout RB’s as well.
Re: Engine builder in Northeast area? [Re: Fern] #3193619
11/27/23 01:47 PM
11/27/23 01:47 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Where are you located and can you expand on REBUILD , what's your time frame .
Re: Engine builder in Northeast area? [Re: Fern] #3193761
11/27/23 08:43 PM
11/27/23 08:43 PM
Central NC
gch Offline
gch  Offline
Central NC
Dwayne porter
Re: Engine builder in Northeast area? [Re: Fern] #3193763
11/27/23 08:46 PM
11/27/23 08:46 PM
AndyF Offline
AndyF  Offline
Start by calling Porter Racing Heads and listening to what Dwayne has to say.
Re: Engine builder in Northeast area? [Re: JohnRR] #3194090
11/29/23 07:20 AM
11/29/23 07:20 AM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
I'm in Massachusetts.
Right now I have a 78 motor 440. Want to build a daily driver with some hp.
Thinking of maybe a 440 source 512 stroker.
Re: Engine builder in Northeast area? [Re: Fern] #3194106
11/29/23 09:59 AM
11/29/23 09:59 AM
U.S.S.A.
U.S.S.A.
Boston area or Berkshires? There are shops I have used in the past north of Boston. I ship my heads to Dwayne Porter, he's in Burlington Vt., I won't let anyone else touch heads past a basic valve job on something I don't care about after a bad experience with a local shop I used for decades bleeped up a set with his COMPETITION valve job.
Sounds like you have a good sized budget if you are talking a 512" stroker ?
Re: Engine builder in Northeast area? [Re: AndyF] #3194235
11/29/23 07:06 PM
11/29/23 07:06 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
He is about 4 hours away from me. I will call him and talk to him. Something closer would work better. I'm just north of Boston.
Re: Engine builder in Northeast area? [Re: Fern] #3194253
11/29/23 07:59 PM
11/29/23 07:59 PM
AndyF Offline
AndyF  Offline
505 is a good combo for a standard bore 440 engine. I'd use Molnar rather than 440 source but 440 Source will work. Just might need to spend a little more at the machine shop to get it right. Getting the rear main to seal can be a real problem with some offshore cranks. If you save a little money on the crank but end up with a leak then you won't be happy. What heads are you planning to use? Only ones I recommend for street engines are the Trick Flow 240 heads. Everything else on the market has issues that need to be fixed by the machine shop so that just shifts money from the purchase price to the total price. What intake? Flat hood or hood scoop? You can make plenty of torque with a flat hood. If you want bigger peak power numbers then you'll need a hood scoop for a tall intake. Hyd roller cam? If so, buy the correct heads with the correct springs so you don't have to pay twice.
Daily driver means small cam and modest compression. You might need to shop a bit to find the right piston to work with your stroke and cylinder head. It is super important to pick the correct piston. I'd use a flat top with a reverse dome dish and keep the compression under 10:1 for street driving. Camshaft should be smaller than what people tell you. Maybe something in the 220 range for smooth idle. 230 range will give you a little more power but idle starts to get lumpy and gas mileage drops. The Chevy 502 crate motor cam is 224/234 and it works great for street rods or daily drivers. Don't let anyone talk you into a big cam that you'll hate driving on a daily basis.
Re: Engine builder in Northeast area? [Re: Fern] #3194390
11/30/23 10:02 AM
11/30/23 10:02 AM
U.S.S.A.
U.S.S.A.
I live north of Boston and it only takes me 3 hrs to get there wink
Re: Engine builder in Northeast area? [Re: AndyF] #3194394
11/30/23 10:05 AM
11/30/23 10:05 AM
U.S.S.A.
U.S.S.A.
Very sound advice given here from someone that has built a bunch of different combinations.
Listen to what he says about buying the cheapest and then spending more than buying a better quality part making it perform as claimed.
Re: Engine builder in Northeast area? [Re: AndyF] #3194549
11/30/23 07:11 PM
11/30/23 07:11 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
That sounds like great advice, thank you. I was thinking 440 source because I heard good things about them. I will give Molnar a look.
Re: Engine builder in Northeast area? [Re: Fern] #3194554
11/30/23 07:43 PM
11/30/23 07:43 PM
AndyF Offline
AndyF  Offline
You can do your own research but once you find an engine builder you should follow his advice. Unless you really want to argue with your engine builder. Engine builders usually hate to have anyone walk into the shop and tell them that "I read on the internet that we should do x,y,z to this engine". That is probably the worst way to start off the relationship!
Re: Engine builder in Northeast area? [Re: AndyF] #3194555
11/30/23 08:01 PM
11/30/23 08:01 PM
NY
B1duster Offline
B1duster  Offline
NY
The engine in my car was built by Danbury Competition Engines in CT.
505 Victor heads close to 700hp
https://danburycomp.com/
Or http://www.larryspower.com/img/BigLogo.gif
A lot closer to you.
And yes, any Head work send to Dwayne - PRH
Re: Engine builder in Northeast area? [Re: B1duster] #3195141
12/03/23 03:33 PM
12/03/23 03:33 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
auto machine east Windsor ct dave miller specialize in mopars,
tell'em gary sent ya
1 of his 10/15 containers
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
