Dumb Predator head question? #3193431
11/26/23 04:38 PM
11/26/23 04:38 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I know there are two types of Predator heads. One fits a Wedge Block and one fits a Hemi...What mods to the block have to be done to run them on a Hemi block? Or is it still a a special order block right out of the gate?
Re: Dumb Predator head question? [Re: Dragula] #3193540
11/27/23 02:36 AM
11/27/23 02:36 AM
iowa
wesw Offline
wesw  Offline
iowa
just order the predator head that fit the hemi block.the top set of holes have studs that screw into the head and go down through the block, put the nuts on from the valley and torque to spec.you can get the head stud kit from Indy.
598 ci predator
Re: Dumb Predator head question? [Re: wesw] #3193830
11/28/23 09:05 AM
11/28/23 09:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I don't think it's a dumb question. But if this helps anymore: if you have a good wedge block, order the wedge pattern Predator heads. Have a hemi block order the hemi bolt-pattern Predators. Like anything else you'll have to clearance things where needed. Often the pushrod area as you can see in other posts here.
Re: Dumb Predator head question? [Re: HardcoreB] #3194077
11/29/23 04:54 AM
11/29/23 04:54 AM
Speaking of future engine builds with Predator heads who is good to use for a tunnel ram intake manifold help?
Re: Dumb Predator head question? [Re: Cab_Burge] #3194092
11/29/23 07:48 AM
11/29/23 07:48 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Carl Foltz. CFE.
Re: Dumb Predator head question? [Re: Cab_Burge] #3194152
11/29/23 01:11 PM
11/29/23 01:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
HRE is who has done mine...
Re: Dumb Predator head question? [Re: Cab_Burge] #3194294
11/29/23 09:31 PM
11/29/23 09:31 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
I would also recommend HRE for a Manifold
Re: Dumb Predator head question? [Re: Cab_Burge] #3194689
12/01/23 01:25 PM
12/01/23 01:25 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Hogan racing manifolds
