Hellcat supercharger on a 6.4 or 5.7 #3192627
11/22/23 02:34 PM
11/22/23 02:34 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Has anyone here done a 6.4 with a HC supercharger or a 5.7 ? Just wondering what results anyone has had if any. Thx RT
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: RTSrunner] #3192796
11/23/23 08:52 AM
11/23/23 08:52 AM
BDW Online content
BDW  Online Content
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: BDW] #3193069
11/24/23 05:21 PM
11/24/23 05:21 PM
Pittsburgh,PA
Pittsburgh,PA
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: RTSrunner] #3193322
11/25/23 11:36 PM
11/25/23 11:36 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
You can but they de-stroked the 6.4 to 6.2 (same block/bore) for a reason. They were also snapping the snouts off blowers from other manufacturers during their testing stage. I guess it all depends what you're using it for
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: Dart 500] #3193345
11/26/23 06:55 AM
11/26/23 06:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Yea, to make a more robust crankshaft. And no where in that article did it mention changing out those hypereutectic pistons.
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: redraptor] #3193538
11/27/23 02:10 AM
11/27/23 02:10 AM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
In the 6.4? The pistons are weak because the ring is so high to meet emissions that they cant take any boost. You're on borrowed time at even 6psi. Hellcat pistons are forged and made by Mahle. Again, its de stroked for a reason. OE engines have to meet a crazy level of abuse - hot lapping in death valley, cold starts and WOT in the arctic. Not changing the oil, using the wrong antifreeze etc
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: Dart 500] #3195574
12/05/23 09:52 PM
12/05/23 09:52 PM
Pahrump NV.
Doright Offline
Doright  Offline
Pahrump NV.
I live on the edge of Death valley I see All the MFG cars come through at the end of summer they all do it at the end of the HOT season for a reason. To pass the Test.
Its all BS
Any engine super charged OR Turbo charged should have Forged pistons PERIOD.
D Barnett
A&P mechanic,
FCC general radio Telephone operator.
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: Dart 500] #3195576
12/05/23 09:56 PM
12/05/23 09:56 PM
Pahrump NV.
Doright Offline
Doright  Offline
Pahrump NV.
They do not move the rings Hi on the pistons for emissions......
D Barnett
A&P mechanic,
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: Doright] #3195632
12/06/23 10:37 AM
12/06/23 10:37 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
The high ring placement has two (2) benefits:
- reduced emissions due to less crevice area above the ring to capture unburned air/fuel mixture
- improved torque due to better combustion efficiency
For OEMs, it's the first reason that drives this trend: https://www.enginebuildermag.com/2005/01/piston-ring-technology-stock-and-performance/
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: Doright] #3195644
12/06/23 12:10 PM
12/06/23 12:10 PM
Pittsburgh,PA
Pittsburgh,PA
If I do this I would definitely add forged pistons and most likely rods too.I've seen the 5.7 rods snap but usually from a hydrolock issue.
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: RTSrunner] #3202525
01/05/24 04:30 PM
01/05/24 04:30 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
A member on my chrysler 300 Fourm did it to his SRT8 300
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Hellcat supercharger on a 6.4 or 5.7 [Re: RTSrunner] #3208794
01/28/24 02:52 PM
01/28/24 02:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Can't think of a rod that wouldn't have hydrolock issues. shruggy
