Help identify this hood release linkage #3192582
11/22/23 11:03 AM
11/22/23 11:03 AM
BRIDGEWATER, CT.
WINGNUT Online content OP
WINGNUT  Online Content OP
BRIDGEWATER, CT.
I have parted many B-bodies over the years. This hood release linkage is either from a 69 Charger or 69 Coronet. It measures 7" end to end. Can someone measure theirs and let me know? Thanks in advance, WINGNUT
Re: Help identify this hood release linkage [Re: WINGNUT] #3192608
11/22/23 01:19 PM
11/22/23 01:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Link rod between outside door handle/lock cylinder and door latch mechanism? shruggy
Re: Help identify this hood release linkage [Re: John_Kunkel] #3192640
11/22/23 03:13 PM
11/22/23 03:13 PM
BRIDGEWATER, CT.
BRIDGEWATER, CT.
Hi John, This linkage is for a hood release, not a door. WINGNUT
Re: Help identify this hood release linkage [Re: WINGNUT] #3192763
11/22/23 11:47 PM
11/22/23 11:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My guess would be for a Charger. The plastic grille was farther forward on the 68-70 (and newer) Chargers were they were on the Coronets. The lever to o[pen the hood was farther forward on the Charger, so that rod to the actual latch had to be longer. Would have been for the grill mounted hood release, not an inside hood release car. Can't help with a part number, but if I was looking for a number, I would be looking in the 68 or 69 parts book, many of the later cars got the inside release. Could also have been used on a 71 & 72 Plymouth Satellite, the non-inside release on those was also more out front then "normal".
Re: Help identify this hood release linkage [Re: poorboy] #3192834
11/23/23 11:48 AM
11/23/23 11:48 AM
BRIDGEWATER, CT.
BRIDGEWATER, CT.
A friend just measured his linkage on his 69 Charger, 8" long. I think you may be right on other models, 70 charger also uses an offset linkage. Anybody with a 70 that can measure it for me? WINGNUT
