electric power washer-recomendations please ?
#3192191
11/20/23 01:00 PM
11/20/23 01:00 PM
Posts: 19,402 north of coder
moparx
i need a power washer, but it has to be an electric one. i know gas powered ones are better, but i have to store this in the heated room between the garage and the house, therefore, it can't obviously have gas in it or the fumes and oder associated with one that runs on fuel. with that said, any recommended brands ? what pressure and gallons per minute ? thanks in advance to those that are smarter than me on this subject.
Re: electric power washer-recomendations please ?
[Re: moparx]
#3192195
11/20/23 01:30 PM
11/20/23 01:30 PM
Posts: 16,479 On the run…
BloFish
On the run…
I recently purchased a Husqvarna pw2000, so far it has been great for medium to light use.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: A12]
#3192220
11/20/23 03:36 PM
11/20/23 03:36 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
I don't like being tied to batteries so I am a gas guy. Put a drain valve on the tank and empty it. I just sold a 3500PSI diesel fueled 220V Hotsy as it was TOO much for what I now need. Bought a 3100 PSI GAS powered Simpson at tractor supply for 299.99. Couldn't be happier with it so far. l have about 10+ hours of run time and works awesome OH and it will clean your butt crack BOB 🤣🤣🤣
[Re: TJP]
#3192237
11/20/23 05:05 PM
11/20/23 05:05 PM
Posts: 10,714 North Dakota
6PakBee
North Dakota
You'll never be happy with an electric model. Been there, regretted that. Just not enough oom-pah-pah to do anything useful.
[Re: 6PakBee]
#3192244
11/20/23 05:46 PM
11/20/23 05:46 PM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
You'll never be happy with an electric model. Been there, regretted that. Just not enough oom-pah-pah to do anything useful. Agree so when the weather get's warm again I'll also get the Simpson 3,700 PSI unit. For now, the 2.000 PSI electric pressure washer does what I need for light vehicle washing, siding cleaning, driveway cleaning, gutter flushing, etc.,
[Re: moparx]
#3192246
11/20/23 05:51 PM
11/20/23 05:51 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
It all depends on what your planned use is for it. I mainly use my electric pressure washer to wash the cars and clean the concrete driveway. I've got 2 of them. The first one that I had bought is a Karcher brand and I've been happy with it. (1750 psi) IIRC I bought it at Lowes about 10 yeaars ago. https://www.kaercher.com/us/home-garden/electric-pressure-washers.htmlThe second one was bought out of the clearance isle at Walmart. It's Hyper Tough brand, it was too good of a deal to pass up. (1700 psi) Both work fine for what I use them for.
[Re: moparx]
#3192765
11/22/23 11:53 PM
11/22/23 11:53 PM
TJP
Omaha Ne
my main goal is just general use plus the occasional blast of a greasy lump after scraping the big chunks off and hosing with a foaming degreaser. i realize an electric washer does not come remotely close to a good gas powered washer, but even if i drained all the gas out and taped up the tank, my bride can smell just the tiniest chemical smell, and would not be happy. get her a nose plug, after smelling your butt crack I'm surprised she has any olfactory sensory neurons left 🤣🤣🍻🦨🦨
[Re: moparx]
#3192845
11/23/23 12:19 PM
11/23/23 12:19 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
My son bought me a Sun Joe and I really like it. It cleans everything I need to do like the mildew on the north side of the house and degrease car parts. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 6PakBee]
#3195037
12/03/23 03:28 AM
12/03/23 03:28 AM
Posts: 7,863 Colorado
Leadfoot
Colorado
You'll never be happy with an electric model. Been there, regretted that. Just not enough oom-pah-pah to do anything useful. And it makes one wonder why. Wouldn't you think that someone would make a 3 horsepower electric motor driven pump instead of those smaller and barely adequate ones?
[Re: Leadfoot]
#3195038
12/03/23 05:29 AM
12/03/23 05:29 AM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
You'll never be happy with an electric model. Been there, regretted that. Just not enough oom-pah-pah to do anything useful. And it makes one wonder why. Wouldn't you think that someone would make a 3 horsepower electric motor driven pump instead of those smaller and barely adequate ones? For the same reason that if you want a strong air compressor……..it takes 220v power to make more than 2hp. 1hp is 755w. 2hp is 1500w. A standard 15amp electrical outlet is about 1800w (rough head math). You CANNOT make a true 3hp device on a standard 15 amp 120v circuit. 220v pressure washers DO exist, but they are more of an industrial ($$$) item.
[Re: moparx]
#3195086
12/03/23 11:43 AM
12/03/23 11:43 AM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Some years ago I bought one from Harbor freight. Used it twice and a plastic manifold molded into the pump broke off. Of coarse no parts available and no warranty. Next time I needed one I spent four times as much for a bigger nicer Karcher. I was never able to get it to pull detergent from either of the 2 detergent tanks. Karcher was not interested in fixing it. Now the water sprays out of the handle soaking the operator. Yep you guessed it another junk plastic part. I need to take it apart and see if Karcher has parts. Maybe I will just adapt a metal wand assembly for a real pressure washer. Note: neither of these failures were from freezing. They were stored in a heated garage that never freezes. Just crap plastic parts that should have been metal.
