Best small block oil pan #3191094
11/15/23 01:12 PM
11/15/23 01:12 PM
Hertford, England
Dartbloke Offline OP
Hertford, England
Looking to gain some horsepower through better oil control on my 360 based 408 stroker. Currently using Milodon 7qt low pro, crank scraper and no windage tray, max rpm 6800. Thinking of swapping to a deep Moroso 20710 8 quart pan with 7 qts in it. Waste of time? Any better idea’s?
Re: Best small block oil pan [Re: Dartbloke] #3191147
11/15/23 03:31 PM
11/15/23 03:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check out some from this company
https://kevkoracing.com/collections/mopar
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best small block oil pan [Re: pittsburghracer] #3191153
11/15/23 03:59 PM
11/15/23 03:59 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
If you don't have a conventional K frame and you can make it work (and you can find one) these are great
WIZE
In Car:
Re: Best small block oil pan [Re: Dartbloke] #3191275
11/15/23 10:35 PM
11/15/23 10:35 PM
A good vacuum pump with a well sealed engine and thin oil up scope
Re: Best small block oil pan [Re: Cab_Burge] #3191301
11/16/23 04:56 AM
11/16/23 04:56 AM
Hertford, England
Hertford, England
Stock K frame unfortunately. I looked at Kevko but wasn’t convinced thier pans were any better that the Milodon I already have. My thinking was keeping the oil well below the crank had to be a good thing…
Re: Best small block oil pan [Re: Dartbloke] #3191328
11/16/23 10:51 AM
11/16/23 10:51 AM
while you're in there add a windage tray (if you can fit it in).
Re: Best small block oil pan [Re: RapidRobert] #3191593
11/17/23 01:03 PM
11/17/23 01:03 PM
Hertford, England
Hertford, England
I’m not convinced windage trays work which is why I use a crank scraper instead. You don’t want the oil splashing back onto the crank once you’ve peeled it off, so I’m thinking a deeper pan and some sort of screen might be the way to go. I don’t even mind building my own pan if someone had a better design than an off the shelf design.
Re: Best small block oil pan [Re: Dartbloke] #3191609
11/17/23 02:01 PM
11/17/23 02:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Windage trays DO work, though I open the louvers a bit on the off-the-shelf trays.
Scrapers and screens also work.
Biggest/deepest pan you can fit is a big deal.
Smokey Yunick proved all that back in the '60s on his Spintron.
On my SB Duster, we just measured the space available, and I had Billet Fabrication in SoCal make me the biggest pan I could get in there.
Had a pass-through for the drag link, and I marked the balancer where the front crank throws had the most clearance from the pan.
Had to be a bit shallow where the K is.
Pan can be off the car in minutes.
Re: Best small block oil pan [Re: pittsburghracer] #3191636
11/17/23 05:10 PM
11/17/23 05:10 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
I really like Kevco pans.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Best small block oil pan [Re: tvt59] #3191643
11/17/23 05:50 PM
11/17/23 05:50 PM
PA.
"Little"John
"Little"John
PA.
After my last dealing with the idiots at Milidon I will never buy another Milidon oil pan.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best small block oil pan [Re: pittsburghracer] #3191781
11/18/23 01:10 PM
11/18/23 01:10 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have heard others say the same thing.
That being said, the Milodon deep pan with the tie rod hole, is in my opinion, a good pan.
On the subject of windage trays, I remember Tom Hoover saying that the depth of the pan becomes less important if you run a windage tray because the windage tray is all the engine really sees.
