Re: Best small block oil pan
[Re: Dartbloke]
#3191328
11/16/23 10:51 AM
11/16/23 10:51 AM
RapidRobert
while you're in there add a windage tray (if you can fit it in).
[Re: pittsburghracer]
#3191636
11/17/23 05:10 PM
11/17/23 05:10 PM
Posts: 324 Northport, al.
tvt59
Northport, al.
I really like Kevco pans.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: tvt59]
#3191643
11/17/23 05:50 PM
11/17/23 05:50 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I really like Kevco pans. After my last dealing with the idiots at Milidon I will never buy another Milidon oil pan.
#3191781
11/18/23 01:10 PM
11/18/23 01:10 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I really like Kevco pans. After my last dealing with the idiots at Milidon I will never buy another Milidon oil pan. I have heard others say the same thing. That being said, the Milodon deep pan with the tie rod hole, is in my opinion, a good pan. On the subject of windage trays, I remember Tom Hoover saying that the depth of the pan becomes less important if you run a windage tray because the windage tray is all the engine really sees.
