Billy Godbold's book is good #3190744
11/14/23 12:53 AM
11/14/23 12:53 AM
AndyF Offline OP
AndyF  Offline OP
Billy Godbold's book on Cams and Valvetrains is available now. I typically buy all the car books that come out and generally they are a disappointment but not this time. Billy packs a ton of tech into this book. In fact, it has so much tech I wouldn't recommend this book for anyone other than serious students. It is not an easy read that you can just skim thru and look at the pictures. He obviously has worked on a lot of really high performance engines and it shows. Some of the stuff he talks about isn't known outside of the handful of guys who build engines that win at the highest levels.
Re: Billy Godbold's book is good [Re: AndyF] #3190770
11/14/23 08:50 AM
11/14/23 08:50 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Thanks for the recommendation. I'll have to pick up a copy to add to my collection along with books from David Vizard and some guy named Finkbeener...
grin
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Billy Godbold's book is good [Re: Brad_Haak] #3190771
11/14/23 08:54 AM
11/14/23 08:54 AM
USA
hudsonhornet7x Offline
USA
What is the title of the book? I will pick up a copy.
Re: Billy Godbold's book is good [Re: hudsonhornet7x] #3190839
11/14/23 02:04 PM
11/14/23 02:04 PM
Out of the State of Confusion
blue_stocker Offline
Is this the one you're talking about?
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Billy Godbold's book is good [Re: blue_stocker] #3190845
11/14/23 02:15 PM
11/14/23 02:15 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I'll add it into my tech collection along with your two.
Carl Kessel
Re: Billy Godbold's book is good [Re: Brad_Haak] #3191227
11/15/23 08:01 PM
11/15/23 08:01 PM
AndyF Offline OP
AndyF  Offline OP
His approach to picking a cam for a max effort race engine is very different than what most engine builders do. I have a couple of high effort engines in the shop at the moment so I'll try some of his tricks. Billy starts with the physical constraints and works backwards. Typically people buy and cam and then see if it fits, or else they buy a cam and kit and bolt it in. Billy says he likes to design a cam around a known, proven valve spring. He also designs around minimum valve to piston clearance on the intake side since the piston will pull the intake charge into the combustion chamber when the piston is very close to the intake valve. And he sorts valve springs by coil bind height and works off of bind height. Most engine builders double check for bind but they don't sort springs by bind height and then set up the valvetrain off the bind height. Of course, what Billy is talking about really only applies to max effort engines. He is working on NHRA class winner type of engine or NASCAR and F1 stuff. Still interesting to see how those guys do stuff even if it isn't needed on the average street rod engine.
Re: Billy Godbold's book is good [Re: AndyF] #3191236
11/15/23 08:32 PM
11/15/23 08:32 PM
gregsdart Offline
gregsdart  Offline
I just recieved my copy. Just a quick glance tells me it will be challenging to take it all in! Then try and put some of it to use.
Re: Billy Godbold's book is good [Re: gregsdart] #3191262
11/15/23 09:36 PM
11/15/23 09:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Any applicability to street applications or just competition?
Re: Billy Godbold's book is good [Re: gregsdart] #3191289
11/16/23 12:26 AM
11/16/23 12:26 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've had the book for several weeks. It definitely challenges my ability to slow down and focus. Speed reading does not work with this stuff.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Billy Godbold's book is good [Re: Hemi_Joel] #3191342
11/16/23 12:18 PM
11/16/23 12:18 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have dealt with Billy off and on while he was still at Comp for over the 30 years that I have worked in the racing industry. He was always very helpful and very knowledgeable.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Billy Godbold's book is good [Re: AndyF] #3193172
11/25/23 10:33 AM
11/25/23 10:33 AM
CA
Bailey Law Offline
Bailey Law  Offline
CA
Thank you! I need to order this book on Amazon.
Udp arrived today, and serious and meticulous technical work has indeed been done. It may be challenging at times, but it's more interesting than all those Botticellis and the like. Found detailed descriptions on how to choose the optimal cam profile, adjust valve clearances.
____________________________________________________________________
In the world of knowledge, its own renaissance has arrived! We delve into the fascinating world with https://gradesfixer.com/q/when-did-the-renaissance-begin-and-end/ which like a skilled car mechanic, reveals the secrets of education. My efficient fuel for successful study with which I break away from the start.
Re: Billy Godbold's book is good [Re: Bailey Law] #3195095
12/03/23 12:31 PM
12/03/23 12:31 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Pulled my copy out of the Amazon package this morning and looked it over briefly. It'll take some time to dig through it work
Re: Billy Godbold's book is good [Re: Brad_Haak] #3195144
12/03/23 03:39 PM
12/03/23 03:39 PM
moparx Offline
moparx  Offline
i started in on my copy, and it is a fascinating read !
i'm certainly not an engine guru, although i have screwed together a "few" over my lifetime, but by the time i get through this book, then re-read many parts over and over like one did in school [if you were inclined to learn anything biggrin] i'm sure i will learn a lot !
provided i can then remember it. laugh2
beer
Re: Billy Godbold's book is good [Re: AndyF] #3195809
12/07/23 04:04 AM
12/07/23 04:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Thank you for the heads up on the book. Just ordered it.
Hope it has rocker arm design in it too.
Re: Billy Godbold's book is good [Re: AndyF] #3195949
12/07/23 07:15 PM
12/07/23 07:15 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Always appreciate your contributions Andy. Thank you
This is a tour of the Speedway Motors museum. Godbold is one of the tour guides.
https://www.youtube.com/watch?v=WCXHrn_jEj0
Re: Billy Godbold's book is good [Re: AndyF] #3199043
12/21/23 06:43 AM
12/21/23 06:43 AM
Belle Fontaine, AL, US
P
Patrickkinc Offline
Patrickkinc  Offline
P
Oh, thank you, I'll take note of that! Currently, I'm pursuing a second degree, which allows me to delve into various subjects and fields, broadening my horizons and increasing my knowledge. I can recommend an excellent article https://reverbico.com/blog/problems-students-face-in-university/ about college essays about overcoming obstacles that will be beneficial to everyone, providing valuable resources for students aiming to expand their knowledge and successfully navigate academic challenges.
