Axle housing ends
#3189749
11/09/23 01:11 AM
11/09/23 01:11 AM
Posts: 15 WA
Air Grabbler
WA
Would one of you fine people with a bare 8 3/4 or Dana 60 housing and the means to measure the axle bearing bore diameter, measure it and provide the info to me?
Thanks!
Re: Axle housing ends
[Re: moparx]
#3189865
11/09/23 03:15 PM
11/09/23 03:15 PM
Posts: 31,051 Oregon
AndyF
what is the axle offset on a dana and 8 3/4 rear ? i forget. Might depend on the application. Bigger cars and trucks used wider brakes and sometimes the engineers used more offset rather than a deeper draw on the backing plate.
[Re: moparx]
#3189873
11/09/23 03:42 PM
11/09/23 03:42 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
what is the axle offset on a dana and 8 3/4 rear ? i forget. By "offset" do you mean "standout", the distance from the housing end to the outside of the axle flange? The 5 x 4 1/2" axle flange standout (measured from housing end, NOT brake backing plate) 2.525"
