1964 b body 4 speed WIW #3189416
11/07/23 04:24 PM
11/07/23 04:24 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Wondering what a 1964 B Body 4 speed is worth.Seems to be in decent shape.Thanks in advance. beer
Re: 1964 b body 4 speed WIW [Re: 5carguy] #3189498
11/07/23 09:34 PM
11/07/23 09:34 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
With the great breadth of information you have given us.....any were between $1 and $25,000. Maybe more if it is a desirable color.
My Monster are real!
Living within your means makes life pretty easy.
Re: 1964 b body 4 speed WIW [Re: 67vertman] #3189532
11/07/23 11:30 PM
11/07/23 11:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Well what color would you like? I'm sure the seller will accommodate at 25,000 whistling
To be a bit more helpful, It's the first year for the 833 and was only used through 65 with the flanged output shaft in the B and C bodies. In 66 they changed to the Slip yoke which most convert to. So the value is there IF one can find the individual doing a concours resto on a 64-5 B or C and the other things like casting dates stampings codes etc. are what's needed. Might Check over at the B and C bodies only forums to see if anyone's looking or has sold one to establish a market price. It's one of those that is likely not worth a lot unless you find the aforementioned individual. Low demand but hard to ffind when one needs it wink
That may be different IF the internals are the same as the 66 and later units.
Maybe someone else will chime in with a bit more knowledge on the value. Might also contact Brewer's to see if he has any interest. beer
Might also want to verify it is a B/C trans as they did make a shorter A body version wink
Re: 1964 b body 4 speed WIW [Re: TJP] #3189547
11/08/23 02:16 AM
11/08/23 02:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
see the problem with the abundance of information one reply for a 4-speed car & another for just a transmission
Re: 1964 b body 4 speed WIW [Re: 6bblgt] #3189667
11/08/23 05:31 PM
11/08/23 05:31 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
1964 Dodge Polara.
1964 Plymouth Fury.
1964 Plymouth Savoy.
1964 Plymouth Belvedere.
1964 Dodge 220 (Canadian)
1964 Dodge 330.
1964 Dodge 440.
And then throw in engine options.
Re: 1964 b body 4 speed WIW [Re: 67vertman] #3189669
11/08/23 05:36 PM
11/08/23 05:36 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Alright enough of being a MopartSmarta$$
A good 1964 good condition B body 4 speed is worth $600 to $800 dollars.
If someone was looking for a date code 4 sp maybe more.
Re: 1964 b body 4 speed WIW [Re: 67vertman] #3189764
11/09/23 08:00 AM
11/09/23 08:00 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Thank You
beer
Re: 1964 b body 4 speed WIW [Re: 6bblgt] #3189833
11/09/23 01:31 PM
11/09/23 01:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Now that you pointed it out YES, and my apologies to Vertman. I assumed due to the lack of info it was just the trans. Still not sure but due to his latest response to vertman I guessing just the trans shruggy beer
Re: 1964 b body 4 speed WIW [Re: TJP] #3189859
11/09/23 02:38 PM
11/09/23 02:38 PM
moparx Online content
moparx  Online Content
and to think, years ago, i couldn't GIVE away one of those B&T transmissions..................
beer
Re: 1964 b body 4 speed WIW [Re: moparx] #3189878
11/09/23 04:24 PM
11/09/23 04:24 PM
Minnesota
peabodyracing Offline
Minnesota
Don't wish to start a debate or offend anyone but in my own experience here in the midwest I've hauled that style of 4 speed around for a number of years to swap meets of all sizes and types. Typically the most I can get out of one in very nice internal shape is $200.
Lead, follow or get the hell out of the way
Re: 1964 b body 4 speed WIW [Re: peabodyracing] #3190045
11/10/23 12:59 PM
11/10/23 12:59 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I agree a BT 64/65 trans is basically on worth what a gear set is worth as a core unit. I have sold a few over the years and unless you find that guy wanting to restore and use a Ball and trunnion 4 speed the value is way down. Most I have sold will be in the 200-250 range with some maybe bringing 300 max in my opinion and past experience from units having nice gear set in them. Regular 66-up 23 splines become more valuable as the years go up with 70-71 units being more desirable and might be in the range given of 600-800, but again I have never personally sold any 23 spline for that amount, and I have probably sold 30 or more over the years.
Matt
Re: 1964 b body 4 speed WIW [Re: 5carguy] #3190051
11/10/23 01:17 PM
11/10/23 01:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Another thing that could affect the price is the gear ratios...there were two in '64, one has a 3.09 first gear and the other is 2.66. The wide gear spread of the 3.09 is usually less desirable.
Re: 1964 b body 4 speed WIW [Re: John_Kunkel] #3190092
11/10/23 04:18 PM
11/10/23 04:18 PM
Minnesota
Minnesota
You’re right John I forgot about the 1st year ratio as I can’t recall the last one I had with a 3.09 in it. No one who’s looked at mine when I’ve had them out for sale has even asked or checked.
Re: 1964 b body 4 speed WIW [Re: John_Kunkel] #3190096
11/10/23 04:35 PM
11/10/23 04:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Wasn't the 3.09 used in the A body versions? beer
Re: 1964 b body 4 speed WIW [Re: TJP] #3190253
11/11/23 02:28 PM
11/11/23 02:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Maybe the B-body with a 273 also...not sure.
Re: 1964 b body 4 speed WIW [Re: John_Kunkel] #3190346
11/11/23 11:10 PM
11/11/23 11:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
not trying to beat a dead horse but I've never seen a earl b body with anything other than a 6, 318 poly, 361,383 or 413. Don't know if they made a 6 with a 4spd but that might make sense, be a pretty rare one i would think shruggy beer
Re: 1964 b body 4 speed WIW [Re: TJP] #3190862
11/14/23 03:24 PM
11/14/23 03:24 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
It was always my understanding the early A body trans used the 3.09 gear set. I switched one into the 68 trans that I installed into a 65 coronet wagon I was running a 3.23 gear in to help in the take off department.
Matt
