Please Help- Need Spark Arrestor for 1978 360 Motorhome #318960
05/15/09 02:07 PM
05/15/09 02:07 PM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
My friend has a 1978 Dodge Motorhome with the 360 Engine. The MH is broke down in the center of his driveway and he needs a spark arrestor (for the ignition system) for it. He has been told that the part was only made for 74-79 and is not available. Basically, he was told GOOD LUCK by the dealerships that he called. Can anyone help out with where I might refer him to. Thanks Guys- If anyone can help I know you can- Take care, Ron
1970 Plymouth Duster 1971 Dodge Challenger 2009 Dodge Challenger R/T 1970 Dodge Dart Swinger 340 4 Speed (Son's) 1985 Chevrolet Corvette (Wife's)
Re: Please Help- Need Spark Arrestor for 1978 360 Motorhome [Re: mopar155] #318961
05/15/09 02:11 PM
05/15/09 02:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's a spark arrestor? I thought those were the things on dirt bike tail pipes to keep from causing fires.
Re: Please Help- Need Spark Arrestor for 1978 360 Motorhome [Re: stumpy] #318962
05/15/09 10:47 PM
05/15/09 10:47 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
A S A for a engine in an RV ? .. NOT needed unless you do not have a tail-pipe. Now for a generator ? ... that is a diff story.
Re: Please Help- Need Spark Arrestor for 1978 360 Motorhome [Re: mopar155] #318963
05/16/09 08:25 PM
05/16/09 08:25 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Electronic Control Unit? Ballast Resistor, coil? Everything else is in the distributor, so to speak. It's probably the ECU or the ballast...post a pic or description of it here - what does the old one look like?
Re: Please Help- Need Spark Arrestor for 1978 360 Motorhome [Re: Sixpak] #318964
05/17/09 10:19 PM
05/17/09 10:19 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I am not sure what a spark arrester is doing on a 360 in a motor home but if it comes down to it, you can drop in a point dist and hook it directly to the battery hot side and bingo you are running. And as long as you put the new point dizzy in the same time as the old electronic one, you dont even need to change the wires in the cap.
