Solid bushed roller choices? #3186958
10/27/23 11:10 PM
10/27/23 11:10 PM
SF Bay Area
cudabill Offline OP
cudabill  Offline OP
SF Bay Area
I'm looking for solid rollers, I want to avoid hydraulic lifter issues and I don't mind adjusting valves, and a motor full of needle bearings make me worry.
- .820 roller (not .750)
- Bushed bearings (not needle)
- Oil-through to pushrods
- Standard height bore compatible (B Block 383)
I found these three, any others I should look at? Should I choose lifters with cup offset or no offset?
https://borowskirace.com/products/b...hanical-roller-lifter?variant=1300705760 - Bronze bushing $1,224
https://iskycams.com/shop/index.php?main_page=product_info&cPath=266&products_id=2249 steel bushing $1,555
?? [no link yet] BAM bushed lifters
?? https://johncalliesinc.com/morel_products.php (Unsure which part is what)
I'm using PAC-1276X beehive springs on 440Source CNC heads, Bullet cam hydraulic 246/251 108lsa .612/.611 lift (1.6 stainless rockers), 440source lightweight 4.25" crank, .030" over 383. Haven't picked pushrods yet.
Current:'70 Barracuda 383 Gran Coupe project,
Past highlights: Datsun roadster/Olds V8, Porsche 924/buick V6, '89 IROC-Z, '00 Vette/procharged LS3, ML63, 335i, 914, 944T, '39 LaSalle sedan project
Re: Solid bushed roller choices? [Re: cudabill] #3186963
10/28/23 12:47 AM
10/28/23 12:47 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Tony at bes told me to use Isky.
Re: Solid bushed roller choices? [Re: Thelma133] #3186964
10/28/23 01:27 AM
10/28/23 01:27 AM
SF Bay Area
cudabill Offline OP
cudabill  Offline OP
SF Bay Area
Re: Solid bushed roller choices? [Re: cudabill] #3186981
10/28/23 08:58 AM
10/28/23 08:58 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'm using those comp cam lifters in my current motor since 2021 , I inspected them earlier this year and they still feel good.
My car is a double duty ride, with this year being more strip,
Price has certainly increased a lot on them since 2020
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Solid bushed roller choices? [Re: 67mprfan] #3187003
10/28/23 11:44 AM
10/28/23 11:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Isky, Bam. Morel and Jesel will if you ask. I have all three in my engines currrently. Had reallly good luck with Isky, we just put a set in one engine I just had on the dyno and the other got Bam lifters.
Re: Solid bushed roller choices? [Re: Al_Alguire] #3187017
10/28/23 12:29 PM
10/28/23 12:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The “regular” BAM 2016’s for $960 are needle bearing lifters.
The bronze bushing version are about $1150, and the DLC coated steel bushing version is about $1360.
The Comp cams sportsman lifters(96829B-16) do not support pushrod oiling.
Re: Solid bushed roller choices? [Re: cudabill] #3187020
10/28/23 12:51 PM
10/28/23 12:51 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Make sure you have the lifter bores bushed, so whichever lifter you use sits square/properly on the cam lobes. My lifter bores were so far off from the factory it was obscene, and caused uneven wear at the roller/lobe interface not to mention the cylinder to cylinder valve timing was likely all over the board.
Re: Solid bushed roller choices? [Re: jbc426] #3187039
10/28/23 02:04 PM
10/28/23 02:04 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use Isky. They have close to 800 passes. Lash stays consistent. I will say the oil feed hole for the roller wheel sets below the bottom of the lifter bore. On last freshen up we put new bushings in deep enough below the bore to cover the hole. That being said they ran with the hole exposed for close to 600 passes. Spring pressures are 310/805. Oil is 5w25 JR1 synthetic changed once a year, roughly 100 passes.
Doug
Re: Solid bushed roller choices? [Re: dvw] #3187063
10/28/23 02:40 PM
10/28/23 02:40 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I run the Morel black mamba. Not bushed but dissimilar metal axle and direct axle oiling.
Re: Solid bushed roller choices? [Re: INTMD8] #3187140
10/28/23 06:30 PM
10/28/23 06:30 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Are any of the premium ones (BAM, Isky Red Zone, Morel) ok for unbushed bores or is it a crapshoot if they'll have oil control issues in a stock B/RB block?
Re: Solid bushed roller choices? [Re: Blusmbl] #3187144
10/28/23 06:36 PM
10/28/23 06:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ve sold several sets of BAM’s to people with unbushed stock blocks.
One of them sent me a little video of him running the priming tool with the manifold off.
He was worried about the flow of oil coming out around the lifter wheel from the EDM oiling to the axle.
It was way less than what I’d seen from similar videos using other lifters.
In the end, the hot oil pressure is fine, and that motor completed drag week this year without issue.
Re: Solid bushed roller choices? [Re: jbc426] #3187152
10/28/23 07:14 PM
10/28/23 07:14 PM
SF Bay Area
cudabill Offline OP
cudabill  Offline OP
SF Bay Area
That's interesting. I'll have my machinist check those lifter bores.
Re: Solid bushed roller choices? [Re: cudabill] #3187178
10/28/23 08:59 PM
10/28/23 08:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
After reading your first two posts Several times I am totally confused. Are you looking for solid or hydraulic roller lifters for your hydraulic roller cam?
Re: Solid bushed roller choices? [Re: fast68plymouth] #3187203
10/28/23 09:40 PM
10/28/23 09:40 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That’s super helpful, thank you!
Re: Solid bushed roller choices? [Re: GomangoCuda] #3187229
10/29/23 12:39 AM
10/29/23 12:39 AM
SF Bay Area
cudabill Offline OP
cudabill  Offline OP
SF Bay Area
I want to use solid roller lifters on my hydraulic roller cam. A gentler lobe, no hydraulic lifter failures, no needle bearings.
T.V. programs my brain ... Engine Masters - Solid roller lifters on a hydraulic cam
https://www.youtube.com/watch?v=GZTdo2-cGCM
Re: Solid bushed roller choices? [Re: cudabill] #3187239
10/29/23 04:16 AM
10/29/23 04:16 AM
Originally Posted by cudabill
[quote=GomangoCuda]
Believe nothing you hear and only half of what you see on programs like that one on engine masters down twocents
Most automotive magazine writers where English majors before they took their first job with an auto magazine, they were not hotrodders or racers before becoming writers for the magazines they ended working forwork work down
I've seen more than one hi po speed shop employees, high performance machine shops and or hi po racing manufacturers reps. feed misinformation intentionally to magazine writers to test them to see how much the writers knew about cars and or racing of almost every type of vehicles, cars, boats, motorcycles and including airplane racing downrantshruggy
Re: Solid bushed roller choices? [Re: Cab_Burge] #3187328
10/29/23 12:29 PM
10/29/23 12:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
[quote=GomangoCuda]
Cab, I understand what you are saying but in my opinion the guy's on Engine Masters are way, way past that.
Bill
Re: Solid bushed roller choices? [Re: cudabill] #3187332
10/29/23 12:40 PM
10/29/23 12:40 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
It can be done and I have done it as well but don't make the mistake in assuming that a hydraulic roller cam has gentler lobes. If you assess the intensity levels between the cams and compare you will find that they are on par with aggressive solid profiles or in a lot of cases more aggressive. They get away with it because the hydraulic lifter is like shock absorber.
I have a marine jet boat application that I used a Hydraulic Roller Marine lobe that is supposed to be more for endurance applications and it has a major intensity level of 29 degrees. That is very aggressive on a solid roller....
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Solid bushed roller choices? [Re: turbobitt] #3188176
11/02/23 12:09 AM
11/02/23 12:09 AM
SF Bay Area
cudabill Offline OP
cudabill  Offline OP
SF Bay Area
Bullet Cams says that cam with solids will work fine.
Quote
If you run the solid lifters then hot lash the cam at .010/.010.
You will be fine and you can run as much spring as you want.
Kirk m
Re: Solid bushed roller choices? [Re: 340Cuda] #3188243
11/02/23 11:20 AM
11/02/23 11:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
[quote=GomangoCuda]
Cab, I understand what you are seeing but in my opinion the guy's on Engine Masters are way, way past that.
Bill
The guys on Engine Masters are far from English Majors. LOL. All 3 have forgotten more than most will know.
69 GTX 68 Road Runner
