67 Fury 440 Stroker Rearend Humming Noise #3186146
10/24/23 11:32 AM
10/24/23 11:32 AM
Berlin, CT
SportFuryS/23383 Offline OP
Confused
Confused
Berlin, CT
Hi Everybody,
Before I start this post I want to mention that I also posted this on the ForCBodiesOnly or FCBO forum as well. I’m trying to help out my stepdad here with the rearend in his ‘67 Fury with a 440 stroker and 3.23 sure-grip 8 3/4. The rearend keeps making a humming noise and gets worse the more you drive it at anything over 25mph. The pumpkin was rebuilt 3 times, this past time being built by a race shop next to my stepdads friends shop with new fluid put in each time. New stock tapered axle bearings were also put in too, and the car was jacked up and put in drive to precisely hear where the noise is coming from and nothing was heard. My stepdad is fed up with this car again as he always is, so I figured I would see what everyone else thinks is wrong with it.
Any tips are greatly appreciated.
Thanks in advance.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: SportFuryS/23383] #3186151
10/24/23 11:48 AM
10/24/23 11:48 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the driveshaft for balance and straightness? Another dumb idea have you checked the exhaust to see if it is hitting anything?
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: SportFuryS/23383] #3186184
10/24/23 02:59 PM
10/24/23 02:59 PM
IMGTX Offline
IMGTX  Offline
No noise while spinning in the air but but noise when tires are rolling makes me wonder.
Have you swapped out the back tires with completely different tires to see if you have a bad one?
Also make sure the u-joints are not overly tight or binding.
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: IMGTX] #3186212
10/24/23 04:24 PM
10/24/23 04:24 PM
A727Tflite Offline
A727Tflite  Offline
Is the whining sound throttle sensitive?
Does it change on hard left or right turns?
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: A727Tflite] #3186228
10/24/23 06:00 PM
10/24/23 06:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are they reusing the same gear set?
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: SportFuryS/23383] #3186303
10/24/23 11:06 PM
10/24/23 11:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by SportFuryS/23383
Hi Everybody,
Thanks in advance.
have you looked elsewhere? A lot of things can make and transmit noise. I'm thinking it's time to look outside the box (pumpkin) twocents
There are some good suggestions above and likely more to follow. Tires might be a good place to start. had one years back that was similar. Drove several around the bend as the tries were new. Iswapped the ones off my 68 and the noise vaporized wink
keep us posted twocents
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: stumpy] #3186386
10/25/23 12:06 PM
10/25/23 12:06 PM
Berlin, CT
Confused
Confused
Berlin, CT
No, it’s all new
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: A727Tflite] #3186387
10/25/23 12:08 PM
10/25/23 12:08 PM
Berlin, CT
Confused
Confused
Berlin, CT
It is throttle sensitive yes, and we are not sure if it changes when it goes hard left or right no so we will have to take it for another ride and find out
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: stumpy] #3186388
10/25/23 12:10 PM
10/25/23 12:10 PM
Berlin, CT
Confused
Confused
Berlin, CT
My stepdad says and I quote, “the driveshaft was straight last I knew”, and that the exhaust is not hitting
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: IMGTX] #3186390
10/25/23 12:13 PM
10/25/23 12:13 PM
Berlin, CT
Confused
Confused
Berlin, CT
No
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: SportFuryS/23383] #3186391
10/25/23 12:13 PM
10/25/23 12:13 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Humming noise would make me want to disassemble (again I know) and check the wear pattern on new gear set.
Facts are stubborn things.
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: larrymopar360] #3186407
10/25/23 01:00 PM
10/25/23 01:00 PM
moparx Online content
moparx  Online Content
take out the rear seat and have someone ride [?] back there to see if the noise can be pinpointed.
i have done that several times in the past.
beats having them riding in the trunk when getting stopped by the police. biggrin
beer
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: SportFuryS/23383] #3186430
10/25/23 01:59 PM
10/25/23 01:59 PM
A727Tflite Offline
A727Tflite  Offline
Hi Everybody,
Thanks in advance.
Please explain rebuilt. New bearings and setup. Or used r & p each time.
It’s my understanding once a gearset is used at a certain setting moving the pattern may result in noise.
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: A727Tflite] #3186444
10/25/23 02:33 PM
10/25/23 02:33 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere......
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: slantzilla] #3186445
10/25/23 02:42 PM
10/25/23 02:42 PM
I would take it to another shop next, what ratio is it?
Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles scope work
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: Cab_Burge] #3186449
10/25/23 02:57 PM
10/25/23 02:57 PM
A727Tflite Offline
A727Tflite  Offline
He mentioned tapered axles bearings, not tapered shafts.
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: A727Tflite] #3186469
10/25/23 03:56 PM
10/25/23 03:56 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
... and it's 3.23 gear .
No hum off the ground , if it's in the rear that would have me checking the axle bearings , is the endplay set right ?
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: JohnRR] #3186494
10/25/23 05:43 PM
10/25/23 05:43 PM
A727Tflite Offline
A727Tflite  Offline
Axle specialist in my area used to tell me that sometimes just touching the brakes - if the noise diminished and returned after letting off the brakes would be another way to see if the rear wheel bearings were at fault. The drum would “pilot” off the shoes and relieve pressure off the bearings. I just used the hard left and right maneuver to test the bearings.
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: A727Tflite] #3186564
10/25/23 11:35 PM
10/25/23 11:35 PM
Berlin, CT
Confused
Confused
Berlin, CT
Hi Everybody,
Thanks in advance.
New everything, even r & p
Re: 67 Fury 440 Stroker Rearend Humming Noise [Re: JohnRR] #3186565
10/25/23 11:38 PM
10/25/23 11:38 PM
Berlin, CT
Confused
Confused
Berlin, CT
My stepdad said he set the endplay, with very little movement. He as you said thinks it maybe the axle bearings
