67 Fury 440 Stroker Rearend Humming Noise
#3186146
10/24/23 11:32 AM
10/24/23 11:32 AM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi Everybody,
Before I start this post I want to mention that I also posted this on the ForCBodiesOnly or FCBO forum as well. I’m trying to help out my stepdad here with the rearend in his ‘67 Fury with a 440 stroker and 3.23 sure-grip 8 3/4. The rearend keeps making a humming noise and gets worse the more you drive it at anything over 25mph. The pumpkin was rebuilt 3 times, this past time being built by a race shop next to my stepdads friends shop with new fluid put in each time. New stock tapered axle bearings were also put in too, and the car was jacked up and put in drive to precisely hear where the noise is coming from and nothing was heard. My stepdad is fed up with this car again as he always is, so I figured I would see what everyone else thinks is wrong with it.
Any tips are greatly appreciated.
Thanks in advance.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 67 Fury 440 Stroker Rearend Humming Noise
[Re: SportFuryS/23383]
#3186303
10/24/23 11:06 PM
10/24/23 11:06 PM
Posts: 15,526 Omaha Ne
TJP
Omaha Ne
Hi Everybody,
Thanks in advance. have you looked elsewhere? A lot of things can make and transmit noise. I'm thinking it's time to look outside the box (pumpkin) There are some good suggestions above and likely more to follow. Tires might be a good place to start. had one years back that was similar. Drove several around the bend as the tries were new. Iswapped the ones off my 68 and the noise vaporized keep us posted
[Re: stumpy]
#3186386
10/25/23 12:06 PM
10/25/23 12:06 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Are they reusing the same gear set? No, it’s all new
[Re: A727Tflite]
#3186387
10/25/23 12:08 PM
10/25/23 12:08 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Is the whining sound throttle sensitive?
Does it change on hard left or right turns?
It is throttle sensitive yes, and we are not sure if it changes when it goes hard left or right no so we will have to take it for another ride and find out
[Re: stumpy]
#3186388
10/25/23 12:10 PM
10/25/23 12:10 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Have you checked the driveshaft for balance and straightness? Another dumb idea have you checked the exhaust to see if it is hitting anything? My stepdad says and I quote, “the driveshaft was straight last I knew”, and that the exhaust is not hitting
[Re: IMGTX]
#3186390
10/25/23 12:13 PM
10/25/23 12:13 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
No noise while spinning in the air but but noise when tires are rolling makes me wonder.
Have you swapped out the back tires with completely different tires to see if you have a bad one? No
#3186391
10/25/23 12:13 PM
10/25/23 12:13 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Humming noise would make me want to disassemble (again I know) and check the wear pattern on new gear set.
Facts are stubborn things.
#3186430
10/25/23 01:59 PM
10/25/23 01:59 PM
Posts: 3,102 Michigan
A727Tflite
Hi Everybody,
Thanks in advance. Please explain rebuilt. New bearings and setup. Or used r & p each time. It’s my understanding once a gearset is used at a certain setting moving the pattern may result in noise.
[Re: A727Tflite]
#3186444
10/25/23 02:33 PM
10/25/23 02:33 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere......
[Re: slantzilla]
#3186445
10/25/23 02:42 PM
10/25/23 02:42 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere...... I would take it to another shop next, what ratio is it? Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles
[Re: Cab_Burge]
#3186449
10/25/23 02:57 PM
10/25/23 02:57 PM
A727Tflite
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere...... I would take it to another shop next, what ratio is it? Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles He mentioned tapered axles bearings, not tapered shafts.
[Re: A727Tflite]
#3186469
10/25/23 03:56 PM
10/25/23 03:56 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere...... I would take it to another shop next, what ratio is it? Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles He mentioned tapered axles bearings, not tapered shafts. ... and it's 3.23 gear . No hum off the ground , if it's in the rear that would have me checking the axle bearings , is the endplay set right ?
[Re: JohnRR]
#3186494
10/25/23 05:43 PM
10/25/23 05:43 PM
A727Tflite
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere...... I would take it to another shop next, what ratio is it? Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles He mentioned tapered axles bearings, not tapered shafts. ... and it's 3.23 gear . No hum off the ground , if it's in the rear that would have me checking the axle bearings , is the endplay set right ? Axle specialist in my area used to tell me that sometimes just touching the brakes - if the noise diminished and returned after letting off the brakes would be another way to see if the rear wheel bearings were at fault. The drum would “pilot” off the shoes and relieve pressure off the bearings. I just used the hard left and right maneuver to test the bearings.
[Re: A727Tflite]
#3186564
10/25/23 11:35 PM
10/25/23 11:35 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi Everybody,
Thanks in advance. Please explain rebuilt. New bearings and setup. Or used r & p each time. It’s my understanding once a gearset is used at a certain setting moving the pattern may result in noise. New everything, even r & p
[Re: JohnRR]
#3186565
10/25/23 11:38 PM
10/25/23 11:38 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere...... I would take it to another shop next, what ratio is it? Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles He mentioned tapered axles bearings, not tapered shafts. ... and it's 3.23 gear . No hum off the ground , if it's in the rear that would have me checking the axle bearings , is the endplay set right ? My stepdad said he set the endplay, with very little movement. He as you said thinks it maybe the axle bearings
