Big block rear main seal #3184438
10/16/23 07:15 PM
10/16/23 07:15 PM
Missouri, U.S.A.
JSSuperbee Offline OP
Missouri, U.S.A.
Can anyone provide me the name and telephone # of a person or outfit that can replace the rear main seal in my '69 383 while still in the car. Someone within 250 miles of St.Louis.
James Stinebaker
Re: Big block rear main seal [Re: JSSuperbee] #3184448
10/16/23 07:36 PM
10/16/23 07:36 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Watch Nicks garage about the 383 that wouldn't stop leaking first.
Re: Big block rear main seal [Re: JSSuperbee] #3184450
10/16/23 07:44 PM
10/16/23 07:44 PM
AndyF Online content
AndyF  Online Content
Back in the old days when rope seals were available you could find shops that would do that work. These days I don't think you'll find many places that are willing to tackle that job. It is a painful process and the odds of success are low. If you pay shop rate you could easily have $500 in the job only to find out that it leaks just as bad as before they changed it.
Re: Big block rear main seal [Re: 71GTX471] #3184451
10/16/23 07:46 PM
10/16/23 07:46 PM
Missouri, U.S.A.
Missouri, U.S.A.
Never heard of this program. Is it a TV program, and does it tell of someone or some place I can take the car for repairs?
James Stinebaker
Re: Big block rear main seal [Re: AndyF] #3184453
10/16/23 07:55 PM
10/16/23 07:55 PM
Missouri, U.S.A.
Missouri, U.S.A.
Andy: That's what I'm experiencing. I've got a new rope seal from 440 Source. I tried installing a neoprene bottom half along with a lot of RTV as demonstrated on MOPAR Joe's web sight. It leaks worse than before.
James Stinebaker
Re: Big block rear main seal [Re: JSSuperbee] #3184468
10/16/23 09:04 PM
10/16/23 09:04 PM
WA
tman Offline
tman  Offline
WA
Its a youtube channel, Here is his latest
https://www.youtube.com/watch?v=IsvKZtRYi3Q
Re: Big block rear main seal [Re: JSSuperbee] #3184492
10/16/23 10:57 PM
10/16/23 10:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
had a customer years ago that had what he thought was a rear main leak on a 340. After several pan gaskets, rear main seals and a new oil pan he brought it to us. My first question was are you sure all the block plugs are tight. Swore they were. OK, we did the rear main and pan gasket again. No change.
Fortunately it was a stick so we dropped the inspection cover and brake cleaned the 💩 out of it. Fired the motor up let it run a few minutes and the leak appeared. Using a small wadded up paper towel on the end of flexible fingers i was able to sneak it up in the bell housing while avoiding the rear main area. When removed fresh oil was on the towel. wink
Pulled the trans & flywheel and found the right galley plug finger tight. 😳. it hasn't leaked a drop since in 15 years. he left a spare pan gasket and i had a buddy make a sign that "Said think outside the pan John"
LOL beer
Re: Big block rear main seal [Re: tman] #3184499
10/16/23 11:43 PM
10/16/23 11:43 PM
Missouri, U.S.A.
Missouri, U.S.A.
Thanks tman: I read all the responses and watched the video and learned a lot from it.
James Stinebaker
Re: Big block rear main seal [Re: JSSuperbee] #3184629
10/17/23 02:49 PM
10/17/23 02:49 PM
IMGTX Offline
IMGTX  Offline
There used to be a tool that looked like a steel mesh fishnet stocking that slipped over the end of the rope seal and held it.
You would feed the other end over the crank and pull the rope seal in place without removing the crank.
Here is a picture.
May not help but it may be a useful tool if you want to do it yourself.
I have seen similar tools for running wiring in conduits.
Re: Big block rear main seal [Re: IMGTX] #3184639
10/17/23 03:51 PM
10/17/23 03:51 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Chinese finger lock.... lol
That is a great idea to pull the seal around.
Re: Big block rear main seal [Re: Cuda340] #3184653
10/17/23 05:20 PM
10/17/23 05:20 PM
New York, USA
Chargerfan68 Offline
New York, USA
I think around here that was called a “sneaky Pete”. I have one around my garage somewhere.
Re: Big block rear main seal [Re: Chargerfan68] #3184710
10/17/23 09:52 PM
10/17/23 09:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Another version, Still available from Lisle LINKY
Re: Big block rear main seal [Re: JSSuperbee] #3184835
10/18/23 01:35 PM
10/18/23 01:35 PM
I would not , and haven't for years on 100+ Mopar V8 motor builds with no leaks, use one of the old hard to seal up rope seals down tsk twocents
I like and use the new brown color Viton seals and then when done use a good, Permatex, brand of grey adhesive silicone to seal the sides and bottom edges of the seal holder to the block joints. I use a thin putty knife with the silicone on it, use as much as needed several times to make sure the sides edges to the block are full and flat and then do the bottom edges to the block wrench up. Take your time and let it sit 24 hours before running the motor againwrench up scope
Re: Big block rear main seal [Re: TJP] #3185152
10/19/23 09:15 PM
10/19/23 09:15 PM
Missouri, U.S.A.
Missouri, U.S.A.
Thanks TJP:
The only problem is.......that shop in Omaha is about 400 miles away. As bad is this thing is leaking I would never make it.
James Stinebaker
Re: Big block rear main seal [Re: Cab_Burge] #3185153
10/19/23 09:20 PM
10/19/23 09:20 PM
Missouri, U.S.A.
Missouri, U.S.A.
I wish you were 2000 miles closer to me.
James Stinebaker
Re: Big block rear main seal [Re: JSSuperbee] #3185157
10/19/23 09:34 PM
10/19/23 09:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks TJP:
Is this a new motor / leak? Has anyone taken the time to verify it is the rear main? Step #1 is diagnosis, IE: verify the source of the leak. That in itself can be time consuming but like the customer above, he threw parts at it but never verified the source.
Rear mains can be cantankerous . But should not leak horribly unless there is a problem. had another with a BB Chevy. The crank journal was pitted. We polished it a bit, put in a double lip seal and improved it but it still leaked a bit. A huge improvement but I told him no guarantees on the longevity or the repair.
Re: Big block rear main seal [Re: JSSuperbee] #3185226
10/20/23 09:51 AM
10/20/23 09:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So what do you have in it for seals now ? The only rope seal I currently trust is the one sold by Best Gaskets ... but that would be near impossible to install in the car ... the one sold now by felpro is crap. A lip seal is tough because the crank surface for the seal is knurled.
Re: Big block rear main seal [Re: JohnRR] #3185412
10/20/23 10:29 PM
10/20/23 10:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Direct connection sold a rear main bearing that directed the oil or relieved the pressure away from the seal area, Just had a small groove in 1/2 of the bearing as i recall.
Did you use any stiffeners to support the RTV? Many use pipe cleaners wink
Re: Big block rear main seal [Re: JSSuperbee] #3185487
10/21/23 12:16 PM
10/21/23 12:16 PM
central il.
second 70 Offline
second 70  Offline
central il.
McQuinn Auto Springfield Il. 217-523--4509 Ask for Dennis.
Re: Big block rear main seal [Re: TJP] #3185532
10/21/23 03:42 PM
10/21/23 03:42 PM
moparx Offline
moparx  Offline
anti-leak main bearings as per the 1999 DC catalog.....[can't say if these are still available,or if the part numbers have been superseded]
P4349004 - B tri-metal std. size, P4876644 - tri-metal .010 undersize
P4349045 - RB/Hemi std. size, P4876645 - RB/Hemi .010 undersize
when looking at the included picture, it appears to show two very slight grooves on each side of the oil feed hole running from the bearing groove toward the inside of the engine.
as it only shows that on one bearing half, with the other bearing half laying on it's side with it's back side showing, i don't know if it's ths same or not.
as to the pipe cleaners, i would rather pack the side grooves completely with hi-temp rtv "adhesive" as opposed to regular old rtv.
beer
