Big block rear main seal
#3184438
10/16/23 07:15 PM
10/16/23 07:15 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
Can anyone provide me the name and telephone # of a person or outfit that can replace the rear main seal in my '69 383 while still in the car. Someone within 250 miles of St.Louis.
James Stinebaker
Re: Big block rear main seal
[Re: JSSuperbee]
#3184450
10/16/23 07:44 PM
10/16/23 07:44 PM
Posts: 31,044 Oregon
AndyF
Can anyone provide me the name and telephone # of a person or outfit that can replace the rear main seal in my '69 383 while still in the car. Someone within 250 miles of St.Louis. Back in the old days when rope seals were available you could find shops that would do that work. These days I don't think you'll find many places that are willing to tackle that job. It is a painful process and the odds of success are low. If you pay shop rate you could easily have $500 in the job only to find out that it leaks just as bad as before they changed it.
[Re: 71GTX471]
#3184451
10/16/23 07:46 PM
10/16/23 07:46 PM
JSSuperbee
Missouri, U.S.A.
Never heard of this program. Is it a TV program, and does it tell of someone or some place I can take the car for repairs?
James Stinebaker
[Re: AndyF]
#3184453
10/16/23 07:55 PM
10/16/23 07:55 PM
JSSuperbee
Missouri, U.S.A.
Andy: That's what I'm experiencing. I've got a new rope seal from 440 Source. I tried installing a neoprene bottom half along with a lot of RTV as demonstrated on MOPAR Joe's web sight. It leaks worse than before.
James Stinebaker
[Re: JSSuperbee]
#3184468
10/16/23 09:04 PM
10/16/23 09:04 PM
Posts: 566 WA
tman
WA
Never heard of this program. Is it a TV program, and does it tell of someone or some place I can take the car for repairs? Its a youtube channel, Here is his latest https://www.youtube.com/watch?v=IsvKZtRYi3Q
[Re: JSSuperbee]
#3184492
10/16/23 10:57 PM
10/16/23 10:57 PM
Posts: 15,383 Omaha Ne
TJP
Omaha Ne
had a customer years ago that had what he thought was a rear main leak on a 340. After several pan gaskets, rear main seals and a new oil pan he brought it to us. My first question was are you sure all the block plugs are tight. Swore they were. OK, we did the rear main and pan gasket again. No change. Fortunately it was a stick so we dropped the inspection cover and brake cleaned the 💩 out of it. Fired the motor up let it run a few minutes and the leak appeared. Using a small wadded up paper towel on the end of flexible fingers i was able to sneak it up in the bell housing while avoiding the rear main area. When removed fresh oil was on the towel. Pulled the trans & flywheel and found the right galley plug finger tight. 😳. it hasn't leaked a drop since in 15 years. he left a spare pan gasket and i had a buddy make a sign that "Said think outside the pan John" LOL
[Re: tman]
#3184499
10/16/23 11:43 PM
10/16/23 11:43 PM
JSSuperbee
Missouri, U.S.A.
Thanks tman: I read all the responses and watched the video and learned a lot from it.
James Stinebaker
[Re: Cuda340]
#3184653
10/17/23 05:20 PM
10/17/23 05:20 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I think around here that was called a “sneaky Pete”. I have one around my garage somewhere.
[Re: TJP]
#3185152
10/19/23 09:15 PM
10/19/23 09:15 PM
JSSuperbee
Missouri, U.S.A.
Thanks TJP:
The only problem is.......that shop in Omaha is about 400 miles away. As bad is this thing is leaking I would never make it.
James Stinebaker
[Re: JSSuperbee]
#3185157
10/19/23 09:34 PM
10/19/23 09:34 PM
TJP
Omaha Ne
Thanks TJP:
The only problem is.......that shop in Omaha is about 400 miles away. As bad is this thing is leaking I would never make it. Is this a new motor / leak? Has anyone taken the time to verify it is the rear main? Step #1 is diagnosis, IE: verify the source of the leak. That in itself can be time consuming but like the customer above, he threw parts at it but never verified the source. Rear mains can be cantankerous . But should not leak horribly unless there is a problem. had another with a BB Chevy. The crank journal was pitted. We polished it a bit, put in a double lip seal and improved it but it still leaked a bit. A huge improvement but I told him no guarantees on the longevity or the repair.
[Re: JSSuperbee]
#3185226
10/20/23 09:51 AM
10/20/23 09:51 AM
Posts: 75,026 U.S.S.A.
JohnRR
U.S.S.A.
Andy: That's what I'm experiencing. I've got a new rope seal from 440 Source. I tried installing a neoprene bottom half along with a lot of RTV as demonstrated on MOPAR Joe's web sight. It leaks worse than before. So what do you have in it for seals now ? The only rope seal I currently trust is the one sold by Best Gaskets ... but that would be near impossible to install in the car ... the one sold now by felpro is crap. A lip seal is tough because the crank surface for the seal is knurled.
[Re: JSSuperbee]
#3185487
10/21/23 12:16 PM
10/21/23 12:16 PM
Posts: 1,708 central il.
second 70
central il.
Can anyone provide me the name and telephone # of a person or outfit that can replace the rear main seal in my '69 383 while still in the car. Someone within 250 miles of St.Louis. McQuinn Auto Springfield Il. 217-523--4509 Ask for Dennis.
[Re: TJP]
#3185532
10/21/23 03:42 PM
10/21/23 03:42 PM
Posts: 19,426 north of coder
moparx
Direct connection sold a rear main bearing that directed the oil or relieved the pressure away from the seal area, Just had a small groove in 1/2 of the bearing as i recall. Did you use any stiffeners to support the RTV? Many use pipe cleaners anti-leak main bearings as per the 1999 DC catalog.....[can't say if these are still available,or if the part numbers have been superseded] P4349004 - B tri-metal std. size, P4876644 - tri-metal .010 undersize P4349045 - RB/Hemi std. size, P4876645 - RB/Hemi .010 undersize when looking at the included picture, it appears to show two very slight grooves on each side of the oil feed hole running from the bearing groove toward the inside of the engine. as it only shows that on one bearing half, with the other bearing half laying on it's side with it's back side showing, i don't know if it's ths same or not. as to the pipe cleaners, i would rather pack the side grooves completely with hi-temp rtv "adhesive" as opposed to regular old rtv.
