Melling HV pump with Milodon cover TQ specs ? #3184291
10/16/23 06:00 AM
10/16/23 06:00 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys,
Can anyone advise what torque do you guys apply to the pump to block mounting bolts with a Milodon cover ?
Thanks !
Re: Melling HV pump with Milodon cover TQ specs ? [Re: LAD 524] #3184306
10/16/23 08:33 AM
10/16/23 08:33 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here's my experience ...
ANY aluminum cover is going to bind with the "stock" torques specs. Not only have I used a couple different aluminum covers but will point out that virtually EVERY used cover you see at swap meets will show significant wear in the cover. This is despite them supposedly being "hard anodized".
What I've started doing is assembling them on a bench with plain nuts and bolts (grade 5). Start by measuring the depth of the pump body and the height of the rotor and stator - make sure there will be clearance once the cover is installed. You want some clearance but no more than .0015. The FSM gives the specs. Now start torqueing the bolts. At about 15 pounds check that the pump spins freely, If so, bump up the torque to 20 and check again. Do this till a) the pump binds or b) you get to 35 foot pounds.
I currently have one that binds at any more than 15 foot pounds ! The bolts are in with lots of red loctite !!
Good luck.
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Stanton] #3184321
10/16/23 09:21 AM
10/16/23 09:21 AM
A727Tflite Offline
A727Tflite  Offline
Good luck.
Good info, nice approach.
Question though. Did you ever use set up blue on the cover and pocket to see where the binding is?
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Stanton] #3184376
10/16/23 01:19 PM
10/16/23 01:19 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Good luck.
I have 2 engines using the full billet Milodon pumps, I'm pretty sure I torque them to less than 15 lb/ft, like you I keep checking the bind with a priming tool by hand 'till I feel it start to bind. IIRC it's around 12 lb/ft with lots of loctite. Luckily we've never had a problem with leaks or anything coming loose.
Re: Melling HV pump with Milodon cover TQ specs ? [Re: A727Tflite] #3184391
10/16/23 02:59 PM
10/16/23 02:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
No I haven't . And I have trouble getting my head around the problem because those aluminum covers are significantly thicker than any stock cast iron piece. And it doesn't seem to matter - the old "cast" Milodon covers will bind and so do the new "billet" ones. I also have a cast piece from Muscle Motors - it binds and I have a billet cover from 440Source and it binds also. I'm stumped. Seems if you just blindly install an aluminum cover at stock torque you're asking for trouble.
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Stanton] #3184398
10/16/23 03:33 PM
10/16/23 03:33 PM
MN
W
Willie68coronet Offline
W
MN
When I put mine on. I noticed no intstructions. So I called Milodon and was told to "seat the bolt head flush with the pump cover. Then tighten it a /8th or a 1/4 of a turn, like a spark plug. I use blew locktite on the bolts and snug it about a 1/8 of a turn. Never a leak.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Willie68coronet] #3184429
10/16/23 06:41 PM
10/16/23 06:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'd be curious to know how much torque it takes to tighten 1/8 or 1/4 turn. That would be a big help.
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Stanton] #3184455
10/16/23 08:19 PM
10/16/23 08:19 PM
State, country, etc.
gss Offline
gss  Offline
I haven't been able to find one of these covers. Does anyone know where to get them? Also, a photo would help me out a lot. Thanks
Re: Melling HV pump with Milodon cover TQ specs ? [Re: gss] #3184461
10/16/23 08:37 PM
10/16/23 08:37 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
I’ve always tighten these bolts to 35lbs and yes red Loctite
....BAD A$$ STREET CAR.....
Re: Melling HV pump with Milodon cover TQ specs ? [Re: gss] #3184477
10/16/23 09:55 PM
10/16/23 09:55 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Milodon #212225. see picture at Marsh Performance, Summit, Mancini, ect Without remote filter, pn#21205
Brian
Re: Melling HV pump with Milodon cover TQ specs ? [Re: '72CudaRacer] #3184516
10/17/23 03:13 AM
10/17/23 03:13 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Good info fellas thanks for sharing, much appreciated up
Will be interesting to see where it binds when I mick it up.
Im replacing the worn out Barton pump with a melling HV and the Milodon cover. When I pulled the old pump I found a freeze plug used to plug a hole in the pump mount face on the block. The other two holes were for the pump drive of course and the block oil feed from the pump.
Any thoughts as to what the plugged hole was for ? shruggy
The block is an MP siamese bore 4.500" bore.
grin
Re: Melling HV pump with Milodon cover TQ specs ? [Re: Stanton] #3184547
10/17/23 08:16 AM
10/17/23 08:16 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good luck.
Re: Melling HV pump with Milodon cover TQ specs ? [Re: HardcoreB] #3184553
10/17/23 08:49 AM
10/17/23 08:49 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Generally that plugged hole is the internal stock pickup hole which, if using an external pickup, you want to plug otherwise it will just suck air and no oil.
