How do I know if my Cone Suregrip is good #3183446
10/12/23 06:27 PM
10/12/23 06:27 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I have a cone sure grip that was reportedly good when removed. It is not in a housing currently, so I can’t do the usual in car checks.
What should I look for when disassembling the unit to tell if it has “too much” wear?
Thanks!
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183450
10/12/23 06:53 PM
10/12/23 06:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Don't tear it down. You can use your axles to test it.
Clamp one axle in a good vice. Slide the Sure Grip on and then the other axle. Use a good sized pry bar between the lug studs to see how hard it is to turn the axle. Seems like the manual calls for 100lb break away. If that's not right, someone will correct it.
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed.
Master, again and still
Re: How do I know if my Cone Suregrip is good [Re: DaveRS23] #3183457
10/12/23 07:11 PM
10/12/23 07:11 PM
BPBP440 Offline OP
BPBP440  Offline OP
I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway.
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183463
10/12/23 07:19 PM
10/12/23 07:19 PM
Kirkland, Washington
Pacnorthcuda Offline
Just bolt a wheel/tire on the axle that’s not in the vice. The old shade tree test was if you can turn the tire with your arms the sure grip is shot. Then you disassemble and resurface (belt sander) the cones, but that’s a different discussion.
Re: How do I know if my Cone Suregrip is good [Re: Pacnorthcuda] #3183485
10/12/23 08:42 PM
10/12/23 08:42 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway. You can just use a lug nut. 100lbs is not too much for them.
Just bolt a wheel/tire on the axle that’s not in the vice. The only down side to that is the weight. Getting kinda heavy out there with one end in a vice.
The old shade tree test was if you can turn the tire with your arms the sure grip is shot. Then you disassemble and resurface (belt sander) the cones, but that’s a different discussion. Yep, .030" to .050" off the small ends of the cones makes it almost as good as new. Such as that is.
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183614
10/13/23 12:42 PM
10/13/23 12:42 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Here's an old pair of axle stubs that I machined so a torque wrench reading could be taken in a vise. If the cones need to be machined, Doc Diff has spacer shims to take up the distance.
https://www.doctordiff.com/8-3-4-cone-sure-grip-shim-pack.html
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183634
10/13/23 01:40 PM
10/13/23 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It was garabge when it was designed, and still is. The reason one would machine the cones and add shims is because it disintegrates every time you turn, sending little pieces of metal into the gear oil that gets run thru the gear teeth and bearings.Save yourself the headaches down the road , you're almost all the way there, toss it in your scrap bin..
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183644
10/13/23 02:20 PM
10/13/23 02:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
No cone sure-grip is any good when you apply power and traction!
I didn't pay attention to JohnRR years ago and junked a brand new Mancini built 742 cased 3rd member after just one season of hard use.
~$1,300.00 in the garbage.
Dana 60 and spool for the win.
'63 Dodge 330
11.19 @ 121 mph
Re: How do I know if my Cone Suregrip is good [Re: GY3] #3183661
10/13/23 03:04 PM
10/13/23 03:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's like buying a Mack truck to pick up eggs at the grocery store. Yeah, it could do that but over kill.
Dana 60 and a spool is not for the same application a cone suregrip was designed for, no wonder it failed.
Re: How do I know if my Cone Suregrip is good [Re: John_Kunkel] #3183784
10/13/23 11:10 PM
10/13/23 11:10 PM
BPBP440 Offline OP
BPBP440  Offline OP
. That is a slick set-up!
Re: How do I know if my Cone Suregrip is good [Re: BPBP440] #3183865
10/14/23 11:49 AM
10/14/23 11:49 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
Quote
I'm not a fan of them either but used em. I would take it apart and look at the condition of the cones. There may be debris or wear. You can grind down any imperfections and get a little more time out of it before it gets worse. If you don't already have one get a magnetic drain/fill plug, It will catch any metallic debris and help keep it out of the cones.
Re: How do I know if my Cone Suregrip is good [Re: Moparite] #3183887
10/14/23 12:38 PM
10/14/23 12:38 PM
Originally Posted by Moparite
Quote
I have glue strong magnets in the housings to catch debris in one of my old drag race cars that I would swap the third members around for different race tracks at higher elevations, I would wipe it cleans each time I had the third member out up scope
the reason for gluing them it was Murphy whistling shruggy
Re: How do I know if my Cone Suregrip is good [Re: Cab_Burge] #3184336
10/16/23 10:06 AM
10/16/23 10:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Quote
I have done the same thing.
