727 2-3 Separator Plate Hole Size #3181856
10/07/23 08:58 AM
10/07/23 08:58 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Installing TransGo TF2 kit. Is there any advantage to not taking hole C in step 1 on page 1 right to .187?
Would smaller help reduce potential 2-3 shift overlap and eliminate the need to restrict the feed to the front clutch?
Re: 727 2-3 Separator Plate Hole Size [Re: GTX MATT] #3181994
10/07/23 05:13 PM
10/07/23 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I always drill them out to 3/16" (if smaller) on the premise that it's easier to drop the VB and install an orifice restrictor in the case if needed than it is to pull the VB and disassemble it.
Re: 727 2-3 Separator Plate Hole Size [Re: GTX MATT] #3182056
10/07/23 09:18 PM
10/07/23 09:18 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
The overlap of the third clutch and the release of the 2nd band cannot be eliminated just made as short as possible. One thing is if you install a shift kit or a manual valve body, the ratio of the band apply lever should match your modification. I kind of fell into a fix for the overlap on my race car several years ago. Had a manual shift valve body and a 4.2 band apply lever. Trans always worked good and never let me down, but when I pulled it for maintenace about every three years the band was always a little dark. I installed one of the blow proof drums with the stainless-steel sleeve, and the next checkup you could still read the part numbers on the band. I guess the stainless was just enough slicker to let the band slip instead of getting hot on the overlap. Follow the band adjustment in the kit it is a little different than the stock. I used to be a member of the Gil Younger school for trans technicians, before he died. He would send us kits to try out before they were released to the public. It also included books and tips also not given in the kits.
Re: 727 2-3 Separator Plate Hole Size [Re: jwb123] #3182202
10/08/23 02:47 PM
10/08/23 02:47 PM
moparx Offline
moparx  Offline
any chance of getting a copy of those extra books and tips ?
beer
Re: 727 2-3 Separator Plate Hole Size [Re: moparx] #3182419
10/09/23 12:24 PM
10/09/23 12:24 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Thanks guys.
I’m setting this up @ 12 springs in the front clutch, .073 clearance, 3.8 KD lever, solid band, early kick-down servo with 2 springs, and the TF2 set up to all of the advised “race” settings, with their supplied restrictor.
4 clutch forward drum. Valve body is a 73 valve body. TA 3500 stall converter.
Any feedback on if this is likely the right track or if I’m likely to have an imbalance causing too much overlap?
Re: 727 2-3 Separator Plate Hole Size [Re: GTX MATT] #3182469
10/09/23 02:06 PM
10/09/23 02:06 PM
moparx Offline
moparx  Offline
i'm thinking i would tap the hole where the restrictor goes in the case to 1/8npt. the hole is already the correct size for the tap.
then get some female hex pipe plugs and drill several different size holes in them to get the results you want.
just make sure the holes are tapped deep enough to allow the plug to seat below the valve body sealing surface.
beer
Re: 727 2-3 Separator Plate Hole Size [Re: GTX MATT] #3182802
10/10/23 03:18 PM
10/10/23 03:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by GTX MATT
Thanks guys.
popcorn
Re: 727 2-3 Separator Plate Hole Size [Re: moparx] #3182805
10/10/23 03:30 PM
10/10/23 03:30 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
beer
I did this mod to mine last week to replace the existing stamped restrictor plug w/ a threaded one drilled to the same .14" orifice.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
