727 2-3 Separator Plate Hole Size
#3181856
10/07/23 08:58 AM
10/07/23 08:58 AM
Posts: 5,166 CT
GTX MATT
CT
Installing TransGo TF2 kit. Is there any advantage to not taking hole C in step 1 on page 1 right to .187?
Would smaller help reduce potential 2-3 shift overlap and eliminate the need to restrict the feed to the front clutch?
Re: 727 2-3 Separator Plate Hole Size
[Re: GTX MATT]
#3181994
10/07/23 05:13 PM
10/07/23 05:13 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I always drill them out to 3/16" (if smaller) on the premise that it's easier to drop the VB and install an orifice restrictor in the case if needed than it is to pull the VB and disassemble it.
[Re: moparx]
#3182419
10/09/23 12:24 PM
10/09/23 12:24 PM
Posts: 5,166 CT
GTX MATT
CT
Thanks guys.
I’m setting this up @ 12 springs in the front clutch, .073 clearance, 3.8 KD lever, solid band, early kick-down servo with 2 springs, and the TF2 set up to all of the advised “race” settings, with their supplied restrictor.
4 clutch forward drum. Valve body is a 73 valve body. TA 3500 stall converter.
Any feedback on if this is likely the right track or if I’m likely to have an imbalance causing too much overlap?
[Re: GTX MATT]
#3182469
10/09/23 02:06 PM
10/09/23 02:06 PM
Posts: 19,587 north of coder
moparx
i'm thinking i would tap the hole where the restrictor goes in the case to 1/8npt. the hole is already the correct size for the tap. then get some female hex pipe plugs and drill several different size holes in them to get the results you want. just make sure the holes are tapped deep enough to allow the plug to seat below the valve body sealing surface.
[Re: moparx]
#3182805
10/10/23 03:30 PM
10/10/23 03:30 PM
Posts: 1,159 Loudoun County, VA
Brad_Haak
Loudoun County, VA
i'm thinking i would tap the hole where the restrictor goes in the case to 1/8npt. the hole is already the correct size for the tap. then get some female hex pipe plugs and drill several different size holes in them to get the results you want. just make sure the holes are tapped deep enough to allow the plug to seat below the valve body sealing surface. I did this mod to mine last week to replace the existing stamped restrictor plug w/ a threaded one drilled to the same .14" orifice.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
