Hemi, power brakes, and the #7 spark plug #3181814
10/06/23 11:34 PM
10/06/23 11:34 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Anyone running a B-body Hemi with power brakes, what do you do to access the #7 plug (other than remove the booster each time)?
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3181815
10/06/23 11:43 PM
10/06/23 11:43 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
I removed the booster each time until I switched to manual Brakes. The Hemi was a pretty tight fit in the street cars, amazing they made it happen.
Re: Hemi, power brakes, and the #7 spark plug [Re: bobby66] #3181837
10/07/23 06:30 AM
10/07/23 06:30 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve only worked on one with power brakes but I thought it had a flexible boot or something like that. It’s been a few year since.
Re: Hemi, power brakes, and the #7 spark plug [Re: fastmark] #3181855
10/07/23 08:57 AM
10/07/23 08:57 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Yes a rubber boot on #7 Back in the day I converted one to manual brakes to make adjusting the valves easier.. The one I have now is a manual brake car
1969 Hemi Roadrunner 2nd owner
Re: Hemi, power brakes, and the #7 spark plug [Re: 69hemibeep] #3181896
10/07/23 11:46 AM
10/07/23 11:46 AM
central il.
second 70 Offline
second 70  Offline
central il.
I don't have a B but I can change #7 on my E body with power brakes. As had been said #7 has a rubber boot and it can bend enough to keep from removing the booster. Then just coming up with right length socket and extension. I can only use racket to break loose and tighten the rest I have to just use the extension.
Yes PIA good luck.
Re: Hemi, power brakes, and the #7 spark plug [Re: second 70] #3181930
10/07/23 01:29 PM
10/07/23 01:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A couple short extensions and a couple flex extensions
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3181931
10/07/23 01:29 PM
10/07/23 01:29 PM
The early, 1966/1967 B body cars had a smaller power brake booster than the non hemi cars is what I'm remembering now shruggy
Maybe not confused
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3181951
10/07/23 02:20 PM
10/07/23 02:20 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I use a spark plug socket with a swivel extension, a very short extension and duck tape the two together to make sure I can get them both out after putting the plug in. I connect the socket after this combo is in the tube and on the plug.
I have not had to move the master cylinder or the booster. Have done this over 10 years now.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Hemi, power brakes, and the #7 spark plug [Re: Kowal] #3181957
10/07/23 02:43 PM
10/07/23 02:43 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Urrr... there's not enough room between the valve cover and the booster to get the plug out, much less get a ratchet in. Kowal, could you post a photo of your brake booster? Mine is the Bendix pictured in the '70 shop manual for the Hemi, though I'm using a different master cylinder. Booster to firewall mounting bracket is aftermarket item that is supposed to be Hemi spec.
I've done the booster-ectomy before to set valve lash and check plugs, and it is a RPITA. Just fishing for a short-cut... maybe an aftermarket booster with a smaller diameter...?
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3181970
10/07/23 03:07 PM
10/07/23 03:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used to have a 69 Roadrunner hemi with power disc brakes.
I could get the plug out , it just took some ingenuity and flex extensions.
Getting the booster off was a different story though. And that required booster R+R
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3181979
10/07/23 04:02 PM
10/07/23 04:02 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
My booster is the stock Hemi booster.
Re: Hemi, power brakes, and the #7 spark plug [Re: gtx6970] #3181981
10/07/23 04:05 PM
10/07/23 04:05 PM
Arlington, Texas
Arlington, Texas
Pulling the booster/master cylinder was a piece of cake on my '69 Road Runner. They did a decent job of engineering that system IMHO....... up
Re: Hemi, power brakes, and the #7 spark plug [Re: gtx6970] #3181983
10/07/23 04:12 PM
10/07/23 04:12 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I do move the booster aside when changing the spark plug tubes, but that isn’t very often. As gtx6790 said with the right extensions as per my pic and a bit of patience you can change the #7 plug with the booster in place, I do it all the time.
Here is another pic, a slightly different master mounted in this pic as I was messing around with braking response with 1 1/8 versus 1 1/32 bore masters. A recent pic
Re: Hemi, power brakes, and the #7 spark plug [Re: ackpht] #3182023
10/07/23 06:35 PM
10/07/23 06:35 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Does your car have the black, ribbed flexable #7 boot? If it does, it will come out. But I didn't say it was easy. I've always hated power steering and brakes on a Hemi.
2011 Drag Pak Challenger
Re: Hemi, power brakes, and the #7 spark plug [Re: Kowal] #3182169
10/08/23 01:40 PM
10/08/23 01:40 PM
moparx Offline
moparx  Offline
where did you get that plug socket with the "built in" swivel ?
i have never seen those before.
beer
Re: Hemi, power brakes, and the #7 spark plug [Re: moparx] #3182186
10/08/23 02:13 PM
10/08/23 02:13 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
beer
With the demise of Sears, I am not sure it is made anymore. A Craftsman socket, 43823 stamped on the side.
Re: Hemi, power brakes, and the #7 spark plug [Re: Kowal] #3182191
10/08/23 02:19 PM
10/08/23 02:19 PM
moparx Offline
moparx  Offline
thank you sir. bow
i'll keep my eye open at my ACE hardware and at the swaps.
in fact, i'll take that part number to ACE and see if it's listed.
beer
Re: Hemi, power brakes, and the #7 spark plug [Re: Kowal] #3182211
10/08/23 03:31 PM
10/08/23 03:31 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
I found a 13/16" swivel spark plug socket on Amazon. Made in Taiwan.
Checked my parts bins and turns out I do have the flexible plug wire tube for #7, but it's not installed on the car, so it looks like a date with the booster whether I like it or not.
Re: Hemi, power brakes, and the #7 spark plug [Re: moparx] #3182405
10/09/23 12:01 PM
10/09/23 12:01 PM
central il.
second 70 Offline
second 70  Offline
central il.
beer
I've had 1 since the 70's and not sure were it is. Never thought much of it and hardly used it and why I probably why I don't know where its at . Lol
Re: Hemi, power brakes, and the #7 spark plug [Re: moparx] #3182541
10/09/23 06:07 PM
10/09/23 06:07 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
80547 is stamped on this Gearwrench 13/16 with intergral swivel and 3/8ths extension
I think Gearwrench makes other plug sizes than 13/16 too
