Re: Hemi, power brakes, and the #7 spark plug
[Re: fastmark]
#3181855
10/07/23 08:57 AM
10/07/23 08:57 AM
Posts: 1,384 Az
69hemibeep
Az
Yes a rubber boot on #7 Back in the day I converted one to manual brakes to make adjusting the valves easier.. The one I have now is a manual brake car
1969 Hemi Roadrunner 2nd owner
[Re: ackpht]
#3181951
10/07/23 02:20 PM
10/07/23 02:20 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I use a spark plug socket with a swivel extension, a very short extension and duck tape the two together to make sure I can get them both out after putting the plug in. I connect the socket after this combo is in the tube and on the plug.
I have not had to move the master cylinder or the booster. Have done this over 10 years now.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#3181957
10/07/23 02:43 PM
10/07/23 02:43 PM
Posts: 3,103 Morgan Hill, CA
ackpht
Morgan Hill, CA
Urrr... there's not enough room between the valve cover and the booster to get the plug out, much less get a ratchet in. Kowal, could you post a photo of your brake booster? Mine is the Bendix pictured in the '70 shop manual for the Hemi, though I'm using a different master cylinder. Booster to firewall mounting bracket is aftermarket item that is supposed to be Hemi spec.
I've done the booster-ectomy before to set valve lash and check plugs, and it is a RPITA. Just fishing for a short-cut... maybe an aftermarket booster with a smaller diameter...?
[Re: ackpht]
#3181979
10/07/23 04:02 PM
10/07/23 04:02 PM
Kowal
Charlotte, NC
I've done the booster-ectomy before to set valve lash and check plugs, and it is a RPITA. Just fishing for a short-cut... maybe an aftermarket booster with a smaller diameter...? My booster is the stock Hemi booster.
[Re: gtx6970]
#3181983
10/07/23 04:12 PM
10/07/23 04:12 PM
Kowal
Charlotte, NC
I used to have a 69 Roadrunner hemi with power disc brakes. I could get the plug out , it just took some ingenuity and flex extensions. Getting the booster off was a different story though. And that required booster R+R I do move the booster aside when changing the spark plug tubes, but that isn’t very often. As gtx6790 said with the right extensions as per my pic and a bit of patience you can change the #7 plug with the booster in place, I do it all the time. Here is another pic, a slightly different master mounted in this pic as I was messing around with braking response with 1 1/8 versus 1 1/32 bore masters. A recent pic
[Re: ackpht]
#3182023
10/07/23 06:35 PM
10/07/23 06:35 PM
Posts: 2,648 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Anyone running a B-body Hemi with power brakes, what do you do to access the #7 plug (other than remove the booster each time)?
Does your car have the black, ribbed flexable #7 boot? If it does, it will come out. But I didn't say it was easy. I've always hated power steering and brakes on a Hemi.
2011 Drag Pak Challenger
[Re: moparx]
#3182186
10/08/23 02:13 PM
10/08/23 02:13 PM
Kowal
Charlotte, NC
where did you get that plug socket with the "built in" swivel ? i have never seen those before. With the demise of Sears, I am not sure it is made anymore. A Craftsman socket, 43823 stamped on the side.
[Re: Kowal]
#3182211
10/08/23 03:31 PM
10/08/23 03:31 PM
ackpht
Morgan Hill, CA
I found a 13/16" swivel spark plug socket on Amazon. Made in Taiwan.
Checked my parts bins and turns out I do have the flexible plug wire tube for #7, but it's not installed on the car, so it looks like a date with the booster whether I like it or not.
[Re: moparx]
#3182405
10/09/23 12:01 PM
10/09/23 12:01 PM
Posts: 1,707 central il.
second 70
central il.
where did you get that plug socket with the "built in" swivel ? i have never seen those before. I've had 1 since the 70's and not sure were it is. Never thought much of it and hardly used it and why I probably why I don't know where its at . Lol
