Re: Best Rockers that fit TF270 heads
[Re: Dragula]
#3181498
10/05/23 08:12 PM
10/05/23 08:12 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
Harland Sharps made for the TF270 style heads.
[Re: AndyF]
#3181569
10/06/23 12:16 AM
10/06/23 12:16 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
RAS rocker arms are very, very nice. I run them on my Coronet since it is a street engine. Can't beat a steel rocker arm for the street. But RAS has been sold a few times and I have no idea how good their stuff is these days. 30 years ago they were the best of the best. My last two dealings with the new owners and Gary when he took the company back where bad I've never had a problem with Harland Sharp in over 40 yrs. of buying and using their products. I do have four sets of Speed Masters I want to try but nothing installed yet. I have also used several sets of Comp Cams Stainless steel rocker arms and they have work well so far in the last two years They fit under stock covers also
[Re: Thelma133]
#3181609
10/06/23 09:43 AM
10/06/23 09:43 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
I bought the Harland Sharps for my set of TF heads. Seconding Mark's suggestion, there are two versions of their non-offset rocker for stock heads, the "KE" version for the Edelbrocks are are the ones the cylinder head was designed for. https://harlandsharp.com/products/big-block-mopar-v8
[Re: AndyF]
#3182353
10/09/23 05:45 AM
10/09/23 05:45 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I like my Crane gold 1.5s . Fit like they are made for them . Been on iron , Stealth and now the 270s . Thousands of miles and passes . And yes i only have run flat tappet cams
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
