Receiver grooves in head #3180577
10/03/23 01:30 PM
10/03/23 01:30 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
I have a set of b1’s that I want for fill in the hoop grooves, what’s best, soft copper wire or, I have some moroso 2 parts epoxy ( I think it’s metal, haven’t opened it yet). Which would be a better choice. Changing from copper to cometic’s.I don’t want to get them welded up and don’t want to deck the heads. Thanx for your input.
Re: Receiver grooves in head [Re: rickraw] #3180837
10/04/23 07:58 AM
10/04/23 07:58 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
It's ability to seal might depend on where the raised bead intersects the 'repaired' area. I know some who've had success using some epoxy on block decks but, I personally just used the correct wide copper wire then filed it down. Details are in my latest build posts. So with that said, depending on the depth and width of the groove you're filling, would help you make that decision.
Re: Receiver grooves in head [Re: HardcoreB] #3180839
10/04/23 08:20 AM
10/04/23 08:20 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I used JB weld on block reciever grooves on a 340 block. It was supercharged running 12 psi. Ran it for years like that.
Doug
Re: Receiver grooves in head [Re: rickraw] #3180877
10/04/23 09:43 AM
10/04/23 09:43 AM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Is the reason you want to fill in the grooves so you don't have to run a copper head gasket?
Re: Receiver grooves in head [Re: R3 Racing] #3180903
10/04/23 11:18 AM
10/04/23 11:18 AM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Yes, I’m going to cometics coz the previous person didn’t put grooves in the liner.
Re: Receiver grooves in head [Re: rickraw] #3180913
10/04/23 11:57 AM
10/04/23 11:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Option 3 would be to deck the block to remove the groove, Depending on how deep it is
Re: Receiver grooves in head [Re: Al_Alguire] #3180951
10/04/23 01:10 PM
10/04/23 01:10 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Someone didn’t put grooves in the liner. This is a KB wedge.
