Pull Trans
#3178167
09/25/23 06:02 PM
09/25/23 06:02 PM
Posts: 395 Milan Ohio
ct440rod
Milan Ohio
70 Challenger 440 727 Trans Do I have to loosen motor mount to pull trans ?
Thanks Rod
Re: Pull Trans
[Re: ct440rod]
#3178333
09/26/23 12:00 PM
09/26/23 12:00 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
70 Challenger 440 727 Trans Do I have to lossen motor mount to pull trans ?
Thanks Rod you're probably going to have to tip the motor to get at the top bolts and to clear the firewall so you will need to decide how much twist your motor mounts can handle.
Re: Pull Trans
[Re: ct440rod]
#3180584
10/03/23 01:44 PM
10/03/23 01:44 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Re: Pull Trans
[Re: ct440rod]
#3181321
10/05/23 12:03 PM
10/05/23 12:03 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Pull the 2 bolts that attach the mount to the trans and drop the crossmember out.
