Crane gone - no more affordable iron adj rockers? #318054
05/14/09 03:24 PM
05/14/09 03:24 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
Cranes ductile adj rockers have been an excellent low cost adjustable rocker arm for decades. (Adjuster bolt issue aside) Isky had some nice ones as well but theirs were much more expensive- the Cranes were/are around $200. Will anyone step up and continue to make them?
Keep old mopars alive.
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318055
05/14/09 03:28 PM
05/14/09 03:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
are you looking to buy some or just thinki9ng out loud ??
there is always offshore sourced alum roller tip units ...
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318056
05/14/09 03:29 PM
05/14/09 03:29 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Contact RAS for a set of bushed rockers with shafts,much nicer than the crane irons.
Re: Crane gone - no more affordable iron adj rockers? [Re: goldmember] #318057
05/14/09 05:42 PM
05/14/09 05:42 PM
Holland MI Ottawa
2
Holland MI Ottawa
I have rune them in the past. I have no plan to run any currently. What is nice about them is their strength- ductile iron- they are tried and true and were affordable. My brother built a 512 with a roller cam .244ish @ .050 and he was gonna buy some rollers arms. I had a set of barely used Cranes I gave to him and 3 years later they have not missed a beat. (no broken adj either) You gotta admit, when the irons are used in their proper application they offer better bang for the buck over the higher priced 1.5 ratio American made roller rockers.
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318058
05/14/09 05:51 PM
05/14/09 05:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The Isky's were well worth the money compared to the Crane's.
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318059
05/14/09 07:03 PM
05/14/09 07:03 PM
AndyF Offline
AndyF  Offline
Unless someone buys the tooling from Crane then they are gone. Isky stopped making rocker arms a long time ago which was too bad. I always thought the Isky nodular rocker arms were the best. Chrysler stopped making the MW rocker arms a really long time ago which was also too bad. Erson dropped their nodular rocker arms a few years ago and now Crane is out of business.
I had a chance to buy the Erson mfg equipment at a very inexpensive price but I just didn't want to get into that business. If I had known that Crane was going broke maybe I would've done it.
Re: Crane gone - no more affordable iron adj rockers? [Re: AndyF] #318060
05/15/09 12:03 AM
05/15/09 12:03 AM
JohnRR Offline
JohnRR  Offline
Re: Crane gone - no more affordable iron adj rockers? [Re: JohnRR] #318061
05/15/09 07:11 AM
05/15/09 07:11 AM
Holland MI Ottawa
2
Holland MI Ottawa
On the same note who currently makes the stamped steel rocker arms for LA, B and RB mopars?
Re: Crane gone - no more affordable iron adj rockers? [Re: JohnRR] #318062
05/15/09 10:44 AM
05/15/09 10:44 AM
AndyF Offline
AndyF  Offline
Yeah, Erson was willing to sell all the inventory plus the mfg equipment for less than $10K. Probably should've done it but I just didn't have the space to take it on.
Re: Crane gone - no more affordable iron adj rockers? [Re: AndyF] #318063
05/15/09 11:08 AM
05/15/09 11:08 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
not sure on the accuracy on this but I was at the machine shop on wendsday and the owner knows someone in the higher ups and said that an austrialn company has purcashed a lot of the stuff from crane and are looking for a new piece of property in the daytona aera to open back up and that some of the old employes have been contacted.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Crane gone - no more affordable iron adj rockers? [Re: dusturbd340W5] #318064
05/15/09 09:56 PM
05/15/09 09:56 PM
Holland MI Ottawa
2
Holland MI Ottawa
I was gonna say the next option if the irons are gone are the Gold Race rockers at around $300....But they were made by Crane as well!
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318065
05/17/09 03:04 PM
05/17/09 03:04 PM
Rochester HIlls, MI
Blue66Charger Offline
Rochester HIlls, MI
Heard Comp might be picking up some of Crane's stuff?
Re: Crane gone - no more affordable iron adj rockers? [Re: Blue66Charger] #318066
05/17/09 06:00 PM
05/17/09 06:00 PM
Holland MI Ottawa
2
Holland MI Ottawa
The thing is there are adj roller tip rockers for $200 and less with alot of negative quality testament to go with. The Crane irons were known to be durable and many prefer the iron over aluminum for a mild solid flat or mild roller. It would be a nice lineup addittion to Comp or any other legit cam maker out there.
Re: Crane gone - no more affordable iron adj rockers? [Re: 2boltmain] #318067
05/17/09 06:02 PM
05/17/09 06:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'd rather see Isky bring back the good ones...
Re: Crane gone - no more affordable iron adj rockers? [Re: 1_WILD_RT] #318068
05/17/09 06:38 PM
05/17/09 06:38 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I run a set of almost 30 year old Crane ductiles with zero problems....I even use the orig flat tip screwdriver adjusters too. I hate to see them go...as the next cheapest rocker that is still available that I would even consider running is in the $500+ range. There just doesn't appear to be anything quality in between....
