need 440 connecting rods, used or new?
#3180248
10/02/23 11:34 AM
10/02/23 11:34 AM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Two of my 440 blocks at the machine shop just came back magged and checked out fine, so I'm looking to start getting parts. I have no connecting rods for them, so I need to either get a set and have them refurbished or buy a new set. Not sure how much power a stock set can handle, so wondering if using 50 year old parts for an engine is good or maybe see if there are some decent aftermarket I/H-beam rods I can get. Unsure of how much power I need to make, but one motor I do plan to build is for a heavy, all metal car (guessing weight to be close to 3500lbs+). Any suggestions would be appreciated.
Re: need 440 connecting rods, used or new?
[Re: metallicareload]
#3180261
10/02/23 12:00 PM
10/02/23 12:00 PM
Posts: 4,683 Wichita
GY3
Wichita
Personally, I wouldn't but I sold a used LY set to a local guy that pushes 1,000 hp using nitrous.
It all depends on your level of risk.
[Re: migsBIG]
#3180271
10/02/23 12:37 PM
10/02/23 12:37 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
I would get a new set of H beams , but take note the aftermarket likes round numbers , stock rod length is 6.768 , aftermarket are 6.760 ...
[Re: GY3]
#3180290
10/02/23 01:06 PM
10/02/23 01:06 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Aftermarker are stronger and you should be able to buy a crank ,rods, piston that are ballanced. Lighter is a good things also.
1971 HEMI E BODY REGISTRY
[Re: migsBIG]
#3180308
10/02/23 02:19 PM
10/02/23 02:19 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
By the time you buy a set of used rods, have them magged, checked for straightness, good bolts installed, and resized, you are almost to the cost of new rods.
New performance aftermarket rods are lighter, and stronger.
IF you are going to be buying custom pistons any way, you have an opportunity to use a smaller wrist pin and a longer rod (which allows a lighter piston) to save reciprocating weight, and even a 2.2 crank pin to permit the use of more available, cheaper chevy bearings.
IF you are going with stock pistons, of course, disregard the last paragraph.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3180360
10/02/23 05:37 PM
10/02/23 05:37 PM
Posts: 201 PA
Scully
PA
IF you are going with stock pistons, of course, disregard the last paragraph. The aftermarket rods may be stronger but they're not lighter.
[Re: Scully]
#3180381
10/02/23 07:51 PM
10/02/23 07:51 PM
Posts: 9,846 MI, usa
dvw
MI, usa
IF you are going with stock pistons, of course, disregard the last paragraph. The aftermarket rods may be stronger but they're not lighter. Depends on the rods. Whether it's a 2.200" crank, .990" pin For example 7.100" Molnars are about 25 grams lighter than a LY rod. Not to mention the .990" pins are lighter. Along with that the piston compression height is shorter with the longer rod making the piston lighter as well. Lots of options. Doug
[Re: EchoSixMike]
#3180587
10/03/23 01:51 PM
10/03/23 01:51 PM
migsBIG
San Jose,CA
Thanks for the info. I have had several members reach out to me with extra parts from their stashes. hope to make a decision this week.
[Re: migsBIG]
#3180967
10/04/23 01:33 PM
10/04/23 01:33 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Forget HP limits. RPM kills rods.
The typical rod failure happens at the top of the exhaust stroke when the crank rips the rod away from the piston.
Compressive failures like bent rods are usually tune related.
Other failures come from rod bolts or bearings but in those cases the rod is just another victim.
In the grand scheme of things is your engine worth the cost of good rods?
[Re: migsBIG]
#3182930
10/10/23 10:43 PM
10/10/23 10:43 PM
Posts: 581 Boise Idaho
65coronet500
Boise Idaho
I might have a set of H beam stock 440’length and piston pin size Please let me look around and see what I have and I’ll get back to you As soon as I can , thanks Matt
All steel 3800 lbs with me in it 65 Coronet 451 CID Indy 440-1 heads by Dwayne Porter racing heads . ..... 10.31 @ 129.4 mph 1.40 60 ft ALL MOTOR!!!!
[Re: 65coronet500]
#3183024
10/11/23 11:38 AM
10/11/23 11:38 AM
migsBIG
San Jose,CA
