Re: Winter Storage / Coolant
[Re: Mopar.70]
#3180167
10/02/23 08:56 AM
10/02/23 08:56 AM
Posts: 2,511 PA
moparacer
PA
Since you have petcocks on the block I would drain and catch it so you can reuse it, I seen its $28 a gallon.... Flush the system out with water and fill with 50/50 antifreeze. Repeat in the spring and put the blue back in. I question just how detrimental it would be to mix regular antifreeze with it. Probably wouldn't hurt anything but at $28 a gallon I am running it through a filter and saving it.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: topside]
#3180789
10/03/23 10:53 PM
10/03/23 10:53 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I have not done this but I heard the idea of using RV antifreeze!
They said it has less residue and easier to remove in the spring/ I am concerned as one way to lower the freezing point is to simply add salt to the water
Has anyone done this?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Mopar.70]
#3181570
10/06/23 12:20 AM
10/06/23 12:20 AM
Posts: 43,211 Bend,OR USA
Cab_Burge
[Re: Leigh]
#3181588
10/06/23 07:54 AM
10/06/23 07:54 AM
Posts: 1,213 Minn
SportF
Minn
