Winter Storage / Coolant #3180154
10/02/23 07:58 AM
10/02/23 07:58 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
So new to me, with the car I have now and NHRA rules as they are can't run standard antifreeze in the motor. I went with a race coolant from Summit Racing (it's blue). Says on the bottle do not mix with regular anti-freeze. I live in Ohio, and garage isn't heated so for winter this stuff needs to come out. I put pet-cocks on both sides of the block. I had planned on draining all this coolant out and putting in regular anti-freeze just for the winter. But with the do not mix warning on the bottle, now I'm second guessing that without a major flushing of the system. What all are you guys doing to store for winter? Just draining it empty? Storing with anti-freeze?
Re: Winter Storage / Coolant [Re: Mopar.70] #3180167
10/02/23 08:56 AM
10/02/23 08:56 AM
PA
moparacer Offline
moparacer  Offline
PA
Since you have petcocks on the block I would drain and catch it so you can reuse it, I seen its $28 a gallon.... eek Flush the system out with water and fill with 50/50 antifreeze.
Repeat in the spring and put the blue back in.
I question just how detrimental it would be to mix regular antifreeze with it. Probably wouldn't hurt anything but at $28 a gallon I am running it through a filter and saving it.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Winter Storage / Coolant [Re: moparacer] #3180246
10/02/23 11:31 AM
10/02/23 11:31 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Can you drain the expensive Blue stuff and save it? If so just leave the system empty for the winter and refill with the saved fluid next season.
Re: Winter Storage / Coolant [Re: cl440] #3180260
10/02/23 12:00 PM
10/02/23 12:00 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
I can drain it, and plan to save it yes. Just wasn't quite sure if it would all come out or be stuck in some pockets somewhere and cause an issue. I had planned for what the previous reply mentioned, to drain, flush, fill and then repeat in the spring. Just wasn't to sure on the mixing being that I'm sure there will be some little bits left somewhere. The stuff is a little different, it stains white when it gets on painted surfaces.
Re: Winter Storage / Coolant [Re: Mopar.70] #3180298
10/02/23 01:40 PM
10/02/23 01:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
"Blue stuff" sounds like Evans, which supposedly doesn't freeze.
On my car (sig pic), even though it always lived in a heated shop, our power occasionally goes out in winter.
I've always just drained its water & Water Wetter (block drains & radiator) and never had an issue.
Water expands when it freezes, but if there's air in the system, I don't think it'll crack anything.
Another alternative is a block heater, or external heat.
Re: Winter Storage / Coolant [Re: topside] #3180789
10/03/23 10:53 PM
10/03/23 10:53 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I have not done this but I heard the idea of using RV antifreeze!
They said it has less residue and easier to remove in the spring/ I am concerned as one way to lower the freezing point is to simply add salt to the water
Has anyone done this?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Winter Storage / Coolant [Re: Kam*Kuda] #3180977
10/04/23 01:50 PM
10/04/23 01:50 PM
moparx Offline
moparx  Offline
i wouldn't add salt !!! eek
as i live where salt brine and plain salt is used on the roads in the wintertime, i would be very concerned using salt would cause severe corrosion issues inside the engine.
cars rust severely here due to the salt used, and i would think the engine water jackets, aluminum water pumps, and radiators of any construction, would be no different.
beer
Re: Winter Storage / Coolant [Re: Mopar.70] #3181410
10/05/23 04:14 PM
10/05/23 04:14 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I know anti freeze is hard to clean up and some tracks ban its use, but I can't find it in the NHRA rulebook where it isn't allowed. Am I missing something? Every year that there is a hard prolonged freeze down here, you hear about some racer that damaged a block because they didn't get the plain water out of their engine. It is difficult to get it completely drained. I think NHRA knows this happens, and would be a reason to not have an outright ban.
Re: Winter Storage / Coolant [Re: 440Brian] #3181527
10/05/23 10:08 PM
10/05/23 10:08 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
One track I run at have it in their rules for a certain ET and quicker can't run normal antifreeze.
Re: Winter Storage / Coolant [Re: Mopar.70] #3181570
10/06/23 12:20 AM
10/06/23 12:20 AM
I would drain both the radiator and block, both sides, and let it sit for the winter. I would pull all the spark plugs and squirt oil into the cylinders and then spin the motor over with the plugs out and then put the plugs back in and make sure to not start again until you put the coolant back in the motor wrench twocents up
Re: Winter Storage / Coolant [Re: Cab_Burge] #3181585
10/06/23 07:33 AM
10/06/23 07:33 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Mine sees -30F possible. As mentioned, I drain race water solution and both sides of the block. Make sure to remove the petcocks, to ensure the block fully drains. I have heard of the possibility of corrosion obstructing the petcock near the end of the drain, holding water behind it and then freezing. I then store with 50-50 glycol.
Re: Winter Storage / Coolant [Re: Leigh] #3181588
10/06/23 07:54 AM
10/06/23 07:54 AM
Minn
SportF Offline
SportF  Offline
Minn
Bingo
