which carb for my baby 318 #317916
05/14/09 12:30 PM
05/14/09 12:30 PM
North Central Florida
E
eightlitermopar Offline OP
E
The spring weather has got me thinking
I am doing some fixing/tuning up on my 318 two barrel in my 69 coronet 4 door.
The 2 barrell has a tag on it saying it is a remanufactured unit in 2006, but already the gaskets are leaking and it just looks rough.
I plan on putting a gasket kit in it to clean it up, but if it still leaks or is more hassle than it is worth, I was thinking about putting a small 4 bbl on it!
If I decide to do this (probably next winters project) which 4 bbl would be best?
I was thinking a 500 cfm eddy?
any suggestions, comments?
thanks
eight
Mopar or no car
Re: which carb for my baby 318 [Re: eightlitermopar] #317917
05/14/09 12:40 PM
05/14/09 12:40 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
For an otherwise stock 318, a Holley 4160 vaccuum secondary 600 cfm on a Edlebrock performer intake (2176)or Edelbrock 500 or 600 cfm carb. I would choose the 600 version of either.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: which carb for my baby 318 [Re: eightlitermopar] #317918
05/14/09 12:55 PM
05/14/09 12:55 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Edelbrock Performer intake, I would try Summits new 600 cfm carb for the street, electric choke should be okay although I haven't heard a review on this carb.
I'm toying with doing this to my truck, I picked upo a Summit intake cheap, and think I'll use the 600 carb, I also have a Summit cam & lifter kit for my 318 that I'd add at the same time.
Re: which carb for my baby 318 [Re: 69DartGT] #317919
05/14/09 01:32 PM
05/14/09 01:32 PM
Missouri
Confusedcuda Offline
Missouri
I had an eddy preformer 500 cfm on my 273 that had headers hipo ign. shift kit in tranny, hyd. cam, in my 67 barracuda, it ran Great! and got decent mileage. You could go bigger, but depends on what you want...
Re: which carb for my baby 318 [Re: eightlitermopar] #317920
05/14/09 01:37 PM
05/14/09 01:37 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
are planning to do any thing else to the engine or keep it stock?
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: which carb for my baby 318 [Re: deansrr] #317921
05/14/09 02:00 PM
05/14/09 02:00 PM
E
E
When I pull the motor, I plan on a complete regasket set, new oil pump while I am in there (since it sucks to change in the car), and stripping/repainting the engine.
If the heads look good, I will leave them alone, put new valve stem seals on.
It already has dual exhaust, I may change the intake/carb.
The only sure change in all of this, I want to change the distributor to a DUI unit. One wire in, all works better. The current distributor is stock with electronic ignition, but I believe it is getting worn. I have an intermittent miss at idle that sometimes occurs on acceleration. I belive the unit is just worn out.
Since I have to pass emissions here, this electronic distributor upgrade is worth it to me.
Anyway, mostly ideas at this point, I am just exploring options so when I get there I will know what I am up against.
thanks
eight
Mopar or no car
Re: which carb for my baby 318 [Re: eightlitermopar] #317922
05/14/09 03:03 PM
05/14/09 03:03 PM
minnesota, USA
greenfire Offline
greenfire  Offline
minnesota, USA
i to have a 318 cid motor in my 74 satellite sebring i have duel exhaust and i recently installed a eddy performer intake with a eddy 600 cmf 4bbl carb manual choke. works good and it will break the tires lose nicely too.
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: which carb for my baby 318 [Re: greenfire] #317923
05/14/09 03:34 PM
05/14/09 03:34 PM
scratchnfotraction Offline
might check phasing of the reluctor on the dist,was a good post on that recently
I would use the stock cast iron intake off any sb engine with a striped down q-jet
the linkage is easy enuff as mopar used it on stock engines
I would run a points dist with a pertronix point s conversion,works great and gives a little better adv curve to the stock engine,IMO
I would also up grade the points style voltage reg to the soild state replacement one they have for the older cars(I am thinking it has a 1 wire
alt and the points style vr)
a good intake for the 318 is the small port LD4B from eddy...kinda old but works right up there on the LD340 level,,,not much gain going to the eddy airgapRPM one over the LD340 intake,IMO
if it dont have headers yet they are worth the headache to run some long tubes and let the teen breath a little,leting more in means letting more out
and with the 8 3/4 (you had..cough,cough) I would run some 3.55 to 391s in that heavy cruzer
but the 8 3/8 you getting could do the same thing adding a sg
if its a peg leg,I recomend some old skool traction bars on that 4 -door sled,it wheel cut the tire spin down some and it will stiffen up the rear spring pack to help launch it
runwhatya brung
Re: which carb for my baby 318 [Re: eightlitermopar] #317924
05/14/09 03:37 PM
05/14/09 03:37 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Is this a streeter .....and MPG a concern ?
Re: which carb for my baby 318 [Re: dOc !] #317925
05/14/09 03:47 PM
05/14/09 03:47 PM
E
E
We do some cruising with this car, its a 4 door so I am not looking to shut down any ricers on main street. I just want it reliable and running well.
I do need to look deeper into the distributor though. The previous owner put an electronic ignition into it, but it doesn't seem to be doing the trick.
any hard acceleration over half throttle predetonates like crazy and lags in power. From my experience it seems to be advancing way too fast....plus it has the miss at idle.
As far as the carb goes, I just don't want to spend extra money on another two barrel. I prefer to get something that is an improvement in air flow.
as the car runs now on the open road, it runs great with the one legger rear. 21-23 mpg has been my best recorded open road run. Can't beat that.
eight.
Mopar or no car
Re: which carb for my baby 318 [Re: scratchnfotraction] #317926
05/14/09 03:50 PM
05/14/09 03:50 PM
E
E
Any link to this thread?
Mopar or no car
Re: which carb for my baby 318 [Re: eightlitermopar] #317927
05/14/09 04:00 PM
05/14/09 04:00 PM
a stock 318 spread bore cast iron intake and a Demonsizzler prepped thermoquad but I would without a doubt address the pinging 1st. What is your initial/total(w vac plugged),stock dist w stock springs/slots? Fastest temp fix may to back off the initial a bit. Do not let it ping.
Re: which carb for my baby 318 [Re: eightlitermopar] #317928
05/14/09 04:04 PM
05/14/09 04:04 PM
no but its in the last couple dasys if you scroll down it called dist phasing or some thing
do a compression test to see if you gots a leaky valve before checking the dist
that could be you miss at idle
an old skool test on the valves was to take a $ bill and stick it at the end of the tail pipe..if it sucks it in and blows it back out poping the $ bill it is in need of a valve job
I would bet the dist is adv to much and pings on light to med throttle
I use a good vac gauge to help set the timming on them
hook it up and adjust till it gets the highest vac reading..back it off one full # then lock it down test drive,a couple wide open throttle blast listening for it pinging..keep backing the timming back out till it just barly pings on a WOT blast
can play with it to see how much it can take adv doing the same thing add till it pings and back off some
this is the most common thing I fix for people after they cant get it tuned up right by ear...allways to much timming
if you run the cheap gas the more time you gotta remove
I got mine set on the edge and it pings at med throttle on cheap gas and no pinging on 92=93 gas
the q-jet will help on mpgs but an eddy is ok and easy to tune like a q-jet also
getting a good tune will help it run better and using the vac gauge will help getting the ping under control
it is hammering the pistons when its pinging and will led to damge in the long run
to much adv of the timming and runing it hard can and will burn a piston right out of a cyl so its worth getting by with less if need be
Re: which carb for my baby 318 [Re: RapidRobert] #317929
05/14/09 08:09 PM
05/14/09 08:09 PM
E
E
Right now I checked it and it is set at 12 deg. initial at idle without the vacumn.
Mopar or no car
Re: which carb for my baby 318 [Re: eightlitermopar] #317930
05/14/09 08:23 PM
05/14/09 08:23 PM
maybe the balencer has sliped
I would double check TDC i=on the #1 piston and look at the timming marks..should be dead on zero and rotor at the #1 plug tem
I run mine around 10-14 but I have a cam in there and not stock
I would back down to 10 and try it,may be no noticable change and the engine just might like it
or use the vac gauge to see how much vac you got and if its steady or bumpy,IMO
Re: which carb for my baby 318 [Re: scratchnfotraction] #317931
05/14/09 08:33 PM
05/14/09 08:33 PM
E
E
Also, since i am asking stupid questions and also to avoid blowing myself up....
When looking directly at the vacumn advance, using an allen wrench....
clockwise = advancing
counter clockwise = retards
correct? I seem to have confused myself
thanks \
eight
Mopar or no car
Re: which carb for my baby 318 [Re: eightlitermopar] #317932
05/14/09 08:40 PM
05/14/09 08:40 PM
correct?
yes and ideally you would want to plug the vac adv & get the initial/curve(springs/slots)/total correct then plug in the vac adv & adjust it for just under no ping at a steady cruise(highest vacuum)
Re: which carb for my baby 318 [Re: RapidRobert] #317933
05/14/09 10:30 PM
05/14/09 10:30 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Use a Thermoquad. I wouldnt run a brand new AFB, even if ya gave me one.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
