M/T ET Street S/S 275/60R15 experience? #3179276
09/29/23 12:50 PM
09/29/23 12:50 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I'm interested in hearing if anyone has experience with the M/T ET Street S/S 275/60R15 which replaced the original ET Street Radial. I know the S/S has a lot more grooves to improve wet road drivability, but don't know how changes between the original and the S/S series have affected on-track performance.
I have some experience with the S/S in the (now discontinued) 305/40R18 size on my 2021, but the old car and the new car are so different that I don't know how much that matters. On the 2021, I'd say they work... "OK"... but not as well as I recall the original tires worked on the '73.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: M/T ET Street S/S 275/60R15 experience? [Re: Brad_Haak] #3179353
09/29/23 04:11 PM
09/29/23 04:11 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
My understanding is the sidewall is softer on the R vs. the SS even though the compound is the same between them, in addition to having no rain grooves.
I have the next size up from those, the 295/65/15 ET Street SS on my car. It's only gone 1.6's for 60' but it dead hooks no problem on a prepped track.
Re: M/T ET Street S/S 275/60R15 experience? [Re: Blusmbl] #3179378
09/29/23 05:29 PM
09/29/23 05:29 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have been 5. Teens on the SS tire . Plenty of cars have been in the 4’s on that tire . It is good . You need radial prep and a decent double adj shock , that’s all up
....BAD A$$ STREET CAR.....
Re: M/T ET Street S/S 275/60R15 experience? [Re: n20mstr] #3179583
09/30/23 02:06 PM
09/30/23 02:06 PM
Loudoun County, VA
Loudoun County, VA
That's encouraging, thanks
Re: M/T ET Street S/S 275/60R15 experience? [Re: Brad_Haak] #3180165
10/02/23 08:49 AM
10/02/23 08:49 AM
an8sec70cuda Offline
It's good, but the R is better. It's more of the same style as the 275 Pro. I use the 295-65 ET Street R.
The R is fine on the street, but the tread pattern is gonna be worse on wet pavement.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T ET Street S/S 275/60R15 experience? [Re: an8sec70cuda] #3201489
01/01/24 08:11 PM
01/01/24 08:11 PM
Loudoun County, VA
Loudoun County, VA
Figured I'd bring this thread back up, rather than start a new one: Anyone have on-track comparisons between an ET Street S/S and the same size ET Street R they can provide? Thx, again
Re: M/T ET Street S/S 275/60R15 experience? [Re: Brad_Haak] #3201728
01/02/24 04:24 PM
01/02/24 04:24 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I ran the Street R's on my 67 Cuda for a season of racing and "drag-n-drive". My car runs very low 11's (11.1), and a best 60ft of 1.49.
the tires held up all season with drag racing and the drag and drive street driving. I ran tubes in mine, and had the pressure down in the 17lb range for some tracks. I use DA shocks, and Smith Racecraft Assassin traction bars.
(I realize that my car is probably slow compared to your combos!)
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: M/T ET Street S/S 275/60R15 experience? [Re: 19swinger70] #3201735
01/02/24 04:55 PM
01/02/24 04:55 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I switched from the 295/65 R15 to the 275/60 R15's but on my pig it didn't make any difference. But the Rocky pretty much dead hooks on ice so I was really doing it to gain a bit more Top end RPM.
WIZE
In Car:
Re: M/T ET Street S/S 275/60R15 experience? [Re: Streetwize] #3201738
01/02/24 04:59 PM
01/02/24 04:59 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have been running them for years on my 92 D150 , it only goes 14.90 -15.00s with 60 fts. in the 2.00s but they work very well even worn out. I drive the truck to the track and never had a problem but then again I don't drive the truck in the rain if I get caught in the rain I just take it slow. I will be buying a new pair in a few months.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: M/T ET Street S/S 275/60R15 experience? [Re: 11secdart] #3202249
01/04/24 06:22 PM
01/04/24 06:22 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I used to run the M/T ET Street S/S 315/60R/15 till it was discontinued, so made the switch to ET Street S/S 295/60/15. I haven’t noticed any real performance drop off, since I made the switch.
I race in Street class, where by we have to race as we would be on the street, with exception we are allowed to use E85. I still have work to do on rear end adjustments, so 60 is only 1.23, best pass to date is 7.40@ 205. Another guy in my class has been high 6’s @215. So a great tyre, can’t believe the 275 would be that much different
