good quality respirator for sanding/grinding?
#3179020
09/28/23 03:52 PM
09/28/23 03:52 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I have not had good luck with 3m respirators such as below. The straps seem to fall apart within a couple of years and the rubber mask degrades and gets all sticky. Anyone else have that experience with the 3M masks and found a brand or model that lasts longer?
Re: good quality respirator for sanding/grinding?
[Re: Exit1965]
#3179038
09/28/23 05:24 PM
09/28/23 05:24 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The straps seem to fall apart within a couple of years Holy crap, do you you expect a lifetime warranty for a $25 mask ?!?!?!
[Re: Stanton]
#3179041
09/28/23 05:41 PM
09/28/23 05:41 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
By the time the straps are crap the filters are toast and should be tossed. I no longer get ones with replaceable filters and just get a whole new one.
[Re: 340SIX]
#3179241
09/29/23 11:24 AM
09/29/23 11:24 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I cannot attest to long term repeated use but I used this mask/respirator for a one time project of painting my inline 4 cyl Suzuki 1100 engine in a small enclosed not real ventilated space- and I was fine. I put it back into the large resealable bag it came in when I was done. That was 7 years ago and its been in its bag since then. It currently looks fine but obviously Id replace all the filters if I were to use it again. https://www.harborfreight.com/paint-body-respirator-kit-large-56983.html
Keep old mopars alive.
[Re: 2boltmain]
#3179267
09/29/23 12:39 PM
09/29/23 12:39 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Any mask rated above N95 is fine for particulates unless you working with asbestos, lead, solvents and/or uncured urethanes (isocyanates, which have no odor and are rather harmful). Yes, all the straps will eventually age out, why they t can't find a longer lasting solution, other than planned replacement is beyond me. I would highly suggest a valved replaceable mask, as long as it's not diseased purposed, as breathing is much easier. Correct fitment is crucial to effectiveness, beards, etc being an issue
[Re: Exit1965]
#3179469
09/29/23 11:27 PM
09/29/23 11:27 PM
jcc
Bitopia
I have a positive pressure silicon mask I use with urethanes, its 30 years old, and is fine, can't remember if/when I replaced the straps. What is the silicon mask cost vs a $5? N95 valve mask, just to consider bang for buck?
[Re: Exit1965]
#3179489
09/30/23 05:18 AM
09/30/23 05:18 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I'm going to go with a North/Honeywell where the mask is made of silicon. Maybe that will last longer. Hopefully the elastic straps will last for a while too. Please give us a review in the future. You might treat just one side of the straps with some kind of spray on protectant and see if that side lasts longer. The oil on the skin of our fingers seems to degrade elastic straps.
[Re: jcc]
#3179566
09/30/23 01:06 PM
09/30/23 01:06 PM
Posts: 983 rust belt
Moparite
rust belt
That's probably because they are made from the same material. I have used ones similar to these with great results. If you have ever ground rust off that dust goes everywhere and mask filters it out.
