Small block windage tray for stroker application #3178610
09/27/23 01:09 PM
09/27/23 01:09 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
What is everyone using for a windage tray on a small 340 block and a 4” crank? I’m using a stock pan as well. This is a street car. The stock one is not hitting that bad so I may be able to space it down and massage it a little.
Re: Small block windage tray for stroker application [Re: fastmark] #3178614
09/27/23 01:27 PM
09/27/23 01:27 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I had a Milodon one and it rubbed when the Milodon deep sump pan was installed. I was turning the engine over by hand and heard a super faint metal on metal sound so I took the pan off and the sound went away. I had already trimmed material off the sides of it and it still rubbed despite it having what appeared to be plenty of clearance with the pan off.
I would put some clay on whatever one your using and then turn it by hand with the pan on and then pull the pan back off to check for any contact. The Milodon one was too wide for the pan and would get wedged up and distorted enough that it would touch the longer crank throws,
Re: Small block windage tray for stroker application [Re: fastmark] #3178671
09/27/23 03:32 PM
09/27/23 03:32 PM
How about trying some hardened head bolt washers under the tray to gain clearances, one each to start with scope wrench up twocents
Re: Small block windage tray for stroker application [Re: Cab_Burge] #3178698
09/27/23 04:25 PM
09/27/23 04:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I haven’t used a windage tray for close to 30 years. My question to you is does it trap oil in, or out. Hmmmmm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block windage tray for stroker application [Re: pittsburghracer] #3178707
09/27/23 05:15 PM
09/27/23 05:15 PM
Washington
madscientist Offline
Washington
Both. If it’s made correctly.
Re: Small block windage tray for stroker application [Re: pittsburghracer] #3178710
09/27/23 05:35 PM
09/27/23 05:35 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
My thought is that gravity draws the oil down into sump and tray keeps it there.
Facts are stubborn things.
Re: Small block windage tray for stroker application [Re: fastmark] #3178725
09/27/23 05:53 PM
09/27/23 05:53 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Windage tray on a street car is waste of time and money. What you want to address is oil control in the pan. Baffles and such to keep oil around the pick up.
Re: Small block windage tray for stroker application [Re: fastmark] #3178837
09/27/23 09:04 PM
09/27/23 09:04 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I used to run the MP windage tray in my 360 build, and for that I think it did what it was meant to do. But that was with a factory oil pan that had some oil baffled welded in.
In my 408 stroker, which has the Milodon 30940 pan that's 8 quarts, I measured things up prior to the assembly, and given that that pan already has a pretty extensive baffle setup, I simply did NOT install the windage tray. I had two to chose from, the original MP or the Milodon one.
Attached is a pic with the dispstick showing the 8 quart "oil-line" (but reversed since the motor is flipped around on the engine stand). This btw is with the crank counterweights at their longest 'reach', meaning the full counterweight is showing.
How is it working out?
Well, the motor seems to be happy, I have good oil pressure, although at idle (800-850) I get down to about 15 PSI with my 10W30 oil grade. This is sufficient, although I would prefer another 5-10 PSI extra.
Re: Small block windage tray for stroker application [Re: Diplomat360] #3178851
09/27/23 09:33 PM
09/27/23 09:33 PM
Washington
Washington
And what happens to that oil level when the oil is hot and thin as water and you step on the brakes? Or put your foot in it? Baffles and oil level don’t do anything for that.
Re: Small block windage tray for stroker application [Re: madscientist] #3178857
09/27/23 10:10 PM
09/27/23 10:10 PM
PA.
"Little"John
"Little"John
PA.
Running 10-30 oil if there was an issue with that I would see it on my RacePak readout like I did on my Canton oil pan.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small block windage tray for stroker application [Re: pittsburghracer] #3178863
09/27/23 10:26 PM
09/27/23 10:26 PM
Washington
Washington
Uncovering the pickup isn’t the only thing to look at, although if you are uncovering the pickup you will be crapping out parts pretty quick.
When I get my garbage on the dyno I’m going to test it without a windage tray and crank scraper, with a windage tray and no scraper, a scraper and no windage tray and then with both the windage tray and the scraper.
I do know when I put it together the last time I picked up 8-10 psi oil pressure everywhere. That tells me the crank scraper is doing work. It also means if that is the case I can drop down to a standard volume pump and that saves some horsepower (maybe).
Re: Small block windage tray for stroker application [Re: fastmark] #3178865
09/27/23 10:31 PM
09/27/23 10:31 PM
AndyF Offline
AndyF  Offline
If you can make a stock one work then do that. You'll be money ahead since the aftermarket trays all cost money and many of them don't work very well.
Re: Small block windage tray for stroker application [Re: madscientist] #3178894
09/28/23 02:39 AM
09/28/23 02:39 AM
[quote=Diplomat360]I
Mine do, both the slosh baffle welded in the oil pan around the oil pickup and the front slosh baffle welded onto the top of the sump in the front of the stock SB oil pans shruggy I do make my own crank scrapers on all of my HiPo motors, BB, gen 2 Hemi and LA motors up sawzall wrench weld
I'm getting ready to build a mild E85 pump fuel turbocharged 360 with a small stoke increase and probably a hydraulic roller lifter cam and lifters with a Holley EFI system. I'm not shooting for the moon on this project, I want to drive it on the street only so I can learn about both EFI and turbo motors first hand luck shruggy I'll try to remember to take and post some pictures of crank scraper and the internal oil pan baffles luck I may end up buying a deeper sump larger capacity aftermarket oil pan, maybe not confused realcrazy
I'm asking for help from above and hoping I don't hurt it learning. work luck oil pan
Re: Small block windage tray for stroker application [Re: Cab_Burge] #3178948
09/28/23 11:36 AM
09/28/23 11:36 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's well-documented since Smokey Yunick discovered it decades ago that the rotating assy pulls the oil in the pan around it like a rope at RPM.
Net effect being aeration, drag on the rotating assy, and less oil for the pickup.
There are a few ways to prevent or at least lessen that; deep pans, scrapers, trays of either louvered or screened design.
Likewise, correct baffling has been proven to work in all forms of racing.
For non-resto/stock-appearing stuff, I like the biggest pan I can run + a louvered or screened tray.
Re: Small block windage tray for stroker application [Re: topside] #3179065
09/28/23 06:30 PM
09/28/23 06:30 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
This is the nice Milodon I have in my 408 Stroker, 8qt sump
Re: Small block windage tray for stroker application [Re: larrymopar360] #3179066
09/28/23 06:31 PM
09/28/23 06:31 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The factory 5.7 has a very nice pan IMO (Charger Police anyway not sure about trucks etc.)
Re: Small block windage tray for stroker application [Re: larrymopar360] #3179150
09/28/23 10:38 PM
09/28/23 10:38 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Same pan as what I'm running, and that's the one with the pan side-flare at the bottom, which means the oil has a lot more room to slosh around there, and that should prevent a lot of that volume making it's way up top.
So for comparison's sake, here are a few pics of what the old 360 motor (stock stroke) with the MP windage tray looked like (using the same disptick I carried over to my 408 stroker, so the "scale" in relation to the rest of the block is the same).
Also included my little DIY factory pan baffle, which was a copy of something from one of the Mopar mags. I think it helped a tad...not sure if that ever translated to any HP gains though?
Re: Small block windage tray for stroker application [Re: Diplomat360] #3180616
10/03/23 02:49 PM
10/03/23 02:49 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Its always been a cryin shame that MaMopar never had some kind of factory sump baffles in the SB oil pan... absolutely asking and inviting for oil pump cavitation whenever hard g-forces (acceleration, deceleration, cornering) would come along. I welded in sump baffles into the bottom of my factory oil pan over 40 years ago when I began autocrossing (and some drag racing, road course racing, etc)... it was the single best modification I'd ever made to save the engine and the internal bearings from self destruction. And... recently, I've been running the Milodon road race oil pan... was a bit difficult to install within the factory k-frame (needing some minor cutting to fit the oil pan's widened sump), as well as fitting the Milodon windage tray (needing LOTS of massaging/radiusing to clear the H-beam rods from my 4" stroker)... but worth the time and expense. Also... the Milodon oil pump tube needed slight massaging (squeezing) to clear the point of contact at the windage tray... so that the pickup would not hold up the pan upon clamping it down.
