CA Autoparts - what the... #3174741
09/12/23 04:36 PM
09/12/23 04:36 PM
High Plains of South Dakota
O
olwhite64 Offline OP
O
I'm trying to buy a set of headers off of this website.
Am I so stupid that I can't figure out how to get past the legal release page that says I won't put these on an emission controlled vehicle?
Is it because of my Ad blocker?
Anybody else willing to try to get farther than I did?
https://caautoparts.com/products/hd...totd6A9KzVcvLDqnEFFRGOWCCnQaAstwEALw_wcB
Re: CA Autoparts - what the... [Re: olwhite64] #3174745
09/12/23 04:51 PM
09/12/23 04:51 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I did, no problem at all. Fill out the boxes, sign your name, check I agree, done.
Currently only running Adblock Plus - free ad blocker. Ghostery, AdNauseam and NoScript currently disabled
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: CA Autoparts - what the... [Re: 3hundred] #3174793
09/12/23 07:48 PM
09/12/23 07:48 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Re: CA Autoparts - what the... [Re: John Brown] #3174873
09/13/23 08:37 AM
09/13/23 08:37 AM
O
O
Finally called them last night - it was my email.
If you have a period in your email before the "@" sign it will kick it back - they told me to remove the periods and try it which worked just fine.
Headers are ordered - we'll see how they look when they show up.
Stainless steel headers for $199 shipped to my door? *Sounds* too good to be true; we shall see but the fact that I got a real person who spoke clear and fluent English on the phone seemed like a good sign to me...?
Or the scam of the century!!!
Re: CA Autoparts - what the... [Re: olwhite64] #3175048
09/13/23 09:28 PM
09/13/23 09:28 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
I poked around in there too. Here's some for a small block pickup or Ramcharger.
https://caautoparts.com/products/hds-dpu67-2wd-lt
Re: CA Autoparts - what the... [Re: olwhite64] #3175134
09/14/23 09:26 AM
09/14/23 09:26 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
shock
Re: CA Autoparts - what the... [Re: Hugh Jorgan] #3175144
09/14/23 11:21 AM
09/14/23 11:21 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
shock
And when they show up you find out the pic of them is actual size......... laugh2
(anyone remember the thread about the vise many years ago where this happened?)
John
Re: CA Autoparts - what the... [Re: SattyNoCar] #3176786
09/20/23 08:11 PM
09/20/23 08:11 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Did you get them yet?
popcorn
Re: CA Autoparts - what the... [Re: Hugh Jorgan] #3178427
09/26/23 04:41 PM
09/26/23 04:41 PM
O
O
Fellas - I don't know what to tell you... but they're amazing. They're highly polished and the welds are awesome. Literally speechless when I pulled them out of the box. I bolted them right up to a motor I had on a stand; the flanges are super thick and as of right now, straight as an arrow!
I can only assume the will not fit in the chassis in some way/shape/form!?!
Re: CA Autoparts - what the... [Re: olwhite64] #3178429
09/26/23 04:49 PM
09/26/23 04:49 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
They look really wide for a truck chassis? I hope I'm seeing this wrong.
My '93 5.7 Ramcharger needed a Jeep Grand Cherokee exhaust manifold on the drivers side to clear the frame, they tried notching the frame but there wasn't enough room.
'69 300 Convertible
'16 300 S Hemi
Re: CA Autoparts - what the... [Re: 3hundred] #3178456
09/26/23 07:00 PM
09/26/23 07:00 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 5.7 is a different critter then a 5.2 or 5.9 Magnum. These headers appear to be bolted to either an LA or a Magnum motor.
If possible, I would like to see a picture from the front of the motor so we can see how close the headers tuck in towards the block. That will give a better idea if they would work on a tight chassis.
Re: CA Autoparts - what the... [Re: poorboy] #3178457
09/26/23 07:06 PM
09/26/23 07:06 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You're right, the hemi head is much wider. IIRC, the JGC manifold didn't exit too far off the starter? Can't go out and look anymore, sold the truck earlier this year.
It's a B engine, guessing the collector is outboard the engine by about a foot?
It's probably fine and I'm over or under thinking it.
'69 300 Convertible
'16 300 S Hemi
Re: CA Autoparts - what the... [Re: 3hundred] #3178549
09/27/23 09:58 AM
09/27/23 09:58 AM
O
O
It's actually for a 440 I'm putting in an '86 Ram 2wd 150.
60k Motorhome motor; just for towing basically - anybody got any cam recommendations (cheap)?
Re: CA Autoparts - what the... [Re: olwhite64] #3178801
09/27/23 08:01 PM
09/27/23 08:01 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Guess I should have looked at the block a little closer. Now its pretty clear its a big block.
In my defense, its been 25 years since I've seen a big block on an engine stand. a poor excuse is better then no excuse... : blush grin
Re: CA Autoparts - what the... [Re: olwhite64] #3178910
09/28/23 07:40 AM
09/28/23 07:40 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Not a cam, but you might consider hyd lifters with “variable duration” design of which the Rhoads Lifter is the best known.
These improve fuel economy at highway cruise, but produce more torque after a downshift to climb a hill at higher rpm.
For ultimate “cheap” you could have your present lifters modified by precision grinding the sides of the lifter piston on two sides.
The third Rhoads lifter US Patent details grinding one or two “flats” a few thousandths deep on the side of the hyd lifter internal piston.
https://patents.google.com/patent/US4524731A/en
If you read the Patent Jack Rhoads’ father got 2 patents before this one. Jack’s son Justin got more Patents.
Improvements on the Rhoads,
of which there are many,
grind a “Trapezoid” shape on either side of the hyd lifter internal piston
or similar.
These hyd lifters do make extra noise at idle.
Some of the US Patents claim one to three MPG improvements for pickup trucks on the highway.
By law, US Patent claims are like “testifying in court under Oath”.
Any hydraulic lifter in an engine with more than 100,000 miles on it
is kind of like a new from the box Rhoads lifter
in that oil is leaking enough inside that the valve lift is shorter and over a shorter duration.
Re: CA Autoparts - what the... [Re: 360view] #3180065
10/01/23 10:04 PM
10/01/23 10:04 PM
Green Bay
Andyvh1959 Offline
Andyvh1959  Offline
Green Bay
These look really tempting for $199, stainless steel. But, am I missing something? How come the tubes aren't fully welded to the head flange?
My 56 C3-B8 Dakota build
Re: CA Autoparts - what the... [Re: Andyvh1959] #3180084
10/01/23 10:31 PM
10/01/23 10:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
most likely welded on the block side of the flange.
Re: CA Autoparts - what the... [Re: Andyvh1959] #3180085
10/01/23 10:31 PM
10/01/23 10:31 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Header tubes are generally welded to the flanges on the motor side, then surface ground so the welds are what actually seal to the heads with the header gaskets. The few tack welds on the outside are most likely to hold the flange in the proper location while the tubes are positioned on a jig for proper angles.
Re: CA Autoparts - what the... [Re: stumpy] #3180343
10/02/23 04:39 PM
10/02/23 04:39 PM
O
O
Correct in this case; these are fully welded and machined flat on the inside.
Re: CA Autoparts - what the... [Re: olwhite64] #3180546
10/03/23 11:35 AM
10/03/23 11:35 AM
moparx Offline
moparx  Offline
agree as well. even TTI pipes are constructed this way.
beer
